Important: A500fu pinout unbricked, gift for atf users Hello to All Atf Users, i've seen a very Big lot of peoples in forum that "Hard Brick" His A500FU and A3 Series tryng of Downgrade Fw from 5.0.1 to 4.4.4, this ISN'T ALLOWED IN THESE SERIES, also Odin or other Box show one Big "PASS". Procedure for unbrick this "A500FU", (Qualcomm based), is Only by "EMMC DIRECT", writing Last "Bootloader version", any Sdc File can Work, any Short of CMD point, (TP), Work with this "Qualcomm Based model", so Here Tested Pinout for EMMC DIRECT Repair: http://i1366.photobucket.com/albums/...psiwd78opg.jpg USE ONLY THIShttp://forum.gsmhosting.com/vbb/imag...ost_thanks.gifBUTTON IN DOWN RIGHT CORNER BR allumts ;) |
Just connect this Pinout and Write Last Stock Fw, (in write choise only BL .bin file), or Only "Bootloader .tar.md5" from "Sammobile" and later reflash with Same Fw with Odin as usual ;) BR allumts |
whats firmware cm and sboot filess?? |
BR allumts |
whats firmware for a5000 |
Br allumts |
tank you..how write sboot?write with emmc tool?help me |
@Morteza pnp Hi flash latest version home tar.MD5 or flash BL tar.MD5 |
with emmc tool?answare |
BR allumts |
================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E conect problem |
Hello, this isn't right, EMMC is good: Quote:
Br allumts |
eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : Q313MB Product Rev : 0.0 Product SN : 849AD613 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100513331334D4200849AD6139223.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
download 5 file a500fu..not cm.bin not sboot.bin..only aboot.mbn sbl1.mbn boot.img...please share file |
