10-10-2017, 13:44 | #61 (permalink) | |
Freak Poster Join Date: Sep 2014 Location: Bahawal Nagar
Member: 2250995 Status: Offline Thanks Meter: 47 | Hv write oNLY BOOT VIA atf but still dead ... Quote:
sucessful write on ATF tooo butstill not download mod beforall opration it was on vibration wen press vol up and down and power button now crunt state http://forum.gsmhosting.com/vbb/f664.../#post12724021 | |
10-31-2017, 19:39 | #62 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Quote: |
11-01-2017, 04:46 | #63 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Manila Phulippines
Member: 1246625 Status: Offline Thanks Meter: 21 | Quote: |
03-04-2018, 18:24 | #69 (permalink) |
Registered User Join Date: Apr 2008 Location: searching new...
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. 3F40FF8080 3FC0FF8080 Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100523331314D4200200ECEDA3291 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : R311MB Product Rev : 0.0 Product SN : 200ECEDA Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100523331314D4200200ECEDA3291.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: aboot.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: tz.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: hyp.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00027FC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: non-hlos.bin 3F40FF8080 3FC0FF8080 Start Writing 0x00007800 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:26 Write Success! Total Images Written: 6 Process Done! write done but still dead any support pls.... |
03-04-2018, 19:14 | #70 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
http://forum.gsmhosting.com/vbb/11827249-post19.html | |
03-04-2018, 19:58 | #71 (permalink) | |
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | Quote:
I have tried this files too.. aboot.mbn, hyp.mbn, rpm.mbn, sbl1.mbn, tz.mbn Same result dead | |
03-05-2018, 11:20 | #72 (permalink) | |
Flash Image: aboot.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: tz.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! still same dead | |
03-10-2018, 06:50 | #73 (permalink) |
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. 3F40FF8080 3FC0FF8080 Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100523331314D4200200ECEDA3291 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : R311MB Product Rev : 0.0 Product SN : 200ECEDA Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100523331314D4200200ECEDA3291.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: MBR + PGPT 3F40FF8080 3FC0FF8080 Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: PIT 3F40FF8080 3FC0FF8080 Start Writing 0x00000010 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT 3F40FF8080 3FC0FF8080 Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: aboot.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:02 Write Success! Flash Image: sbl1.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3FC0FF8080 Total Elapsed Time 00:00:03 Write Success! Flash Image: rpm.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3FC0FF8080 Total Elapsed Time 00:00:04 Write Success! Flash Image: tz.mbn 3F40FF8080 3FC0FF8080 Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3F40FF8080 3FC0FF8080 Total Elapsed Time 00:00:04 Write Success! Total Images Written: 4 Process Done! done after lots of try but without supporter good response ... |
