03-25-2014, 13:50 | #46 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | H9DP32A4JJAC not support? Code: 16:56:43 : ERROR: EMMC IS NOT Ready! (CMD1) 16:56:43 : Try to Adjust VCCIO Voltage 16:56:43 : CMD1 Reply: 0x00FF8080 IC normally detect at u8815 via RIFF |
The Following User Says Thank You to layder For This Useful Post: |
03-31-2014, 22:23 | #47 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | For those like me that bought GPG ATF 5in1 cable.. i don't know what they had smoked but the connection is completely different ! This is the pinout provided by lalitjsraks (the correct) : pin 2- 2.8v vddf pin 5-blue cmd pin 6-red clk pin 7-brown gnd pin 8-green data0 And this is what i’ve found inside gpg cable, coming from RJ45 , i had to open it losing my warranty because i never received support from GPG team.. very bad !! pin 1 (white) - 5V usb (used to make 1.8v and 3.3v) AND cmd !! oh my *** pin 2 (red) - not connected, cable CUT pin 3 (yellow) - clk pin 4 (orange)- jtag TDO pin 5 (green) - data0 pin 6 (black) - jtag TCK pin 7 (brown) - gnd (wow! at least one good) pin 8 (blue) - jtag TMS So if you use this cable without modifications, the connection with the emmc doesn’t work. I don't know also if VCC 5v connected to CMD line can damage the emmc. If you break this line you loose the 1.8v voltage regulator and you have to use an external power supply. At this point.. it is better to build an interface yourself. GPG Team please correct me if i am wrong, and supply a decent user manual with your products. |
04-07-2014, 01:17 | #48 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Product fifth grade, very bad, stabilized voltages are not used since no voltage regulators, for example voltage at 1.8V and a 3.3V voltage. Thus there is a high possibility of damaging the EMMC Chip, I had to open and modify the PCB myself adding voltage regulators. GPG Industries anymore. |
04-18-2014, 12:29 | #51 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | i have emmc chip which is not on pcb. how i can use external power supply? i dont have a emmc socket. i want to solder wires directly to emmc pins. thx and br Gesendet von meinem GT-I9100 mit Tapatalk |
04-18-2014, 16:11 | #53 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | pin 2 - 2.8v vddf pin 5 - cmd pin 6 - clk pin 7 - gnd pin 8 - data0 1.8v I made from cutted pcd with IC from SE K500 (flash ic power) (power to 1,8v DC converter from pin1 atf box (4-5v) at my cable red - +2.8v, brown - GND, 2 resistors from 1,8v to data0 - 51kOm, to cmd - 10kOm |
The Following 5 Users Say Thank You to layder For This Useful Post: |
04-18-2014, 23:07 | #54 (permalink) |
Member: 1873863 Status: Offline Thanks Meter: 67 | I have another eMMC with the same symptom as the nokia eMMC. This one comes from an i9300. Apparently dead.. I have soldered the chip following the schematics, put 2.8v on VDDF and 1.8v on VDD. By selecting "Scan Emmc" i got this results : Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501003030303030305620110726 CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 17179869184 BYTES BOOT PARTITION SIZE: 512 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 5.6 Product SN : 20110726 Manufactured : January 2005 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501003030303030305620110726_BD9F6C12.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ On ATF Software i have selected 2.8v , 7.5Mhz (also tried 15, 3.75) and 16GB, read user partition, default block size. What can it be ?? really damaged un-readable chip ?? Thanks for your help |
04-20-2014, 12:47 | #55 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Russia norten-caucasus Age: 52
Member: 18234 Status: Offline Thanks Meter: 97 | Quote:
04-21-2014, 18:42 | #56 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | true pinout: pin 2 - 1,8/2.8/3,3v VDD pin 5 - cmd pin 6 - clk pin 7 - gnd pin 8 - data0 pin 1 - from 5v to 2,8/3,3v VDDF DC/DC converter Data0 to VDD - 51kOm reststor CMD to VDD - 10kOm reststor |
04-27-2014, 23:37 | #57 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | do i need to solder pin vddf to pin of emmc when the chip is not on the pcb? i tried without pin1 but emmc cant get scanned. i solder only pin 2, 5, 6, 7, 8 to emmc chip. i use modified atf lightning dongle. but also if it is not modified the 2.8V which i need is default in this dongle i guess. can anybody help me? Gesendet von meinem GT-I9100 mit Tapatalk |
04-28-2014, 07:51 | #58 (permalink) | |
but if you want to connect a flash ic that is soldered on the board, use the pinout pin 2 - 1,8/2.8/3,3v VDD pin 5 - cmd pin 6 - clk pin 7 - gnd pin 8 - data0 pin 1 - from 5v to 2,8/3,3v VDDF DC/DC converter Data0 to VDD - 100Om reststor CMD to VDD - 100Om reststor Last edited by nafanya; 04-28-2014 at 07:57. | |
04-28-2014, 08:32 | #59 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | in the last post of layder (#61) he gives the pinout what you describe is for soldering a flash ic when it is on the board. i need the pinout when the flash ic is not on the board. br |
04-28-2014, 09:15 | #60 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Pinout for Flash w/o board. If you solder pin to board, you you need additional power from external supply (VDD/VDDF line may consume more amperage). At board also exist resistors to CMD/Data0 |
