J700h boot repair problem,need help please i am repairing boot very first time,facing problem need help please scan Emmc here http://i.imgur.com/X91FdZc.png when i try to write here is result http://i.imgur.com/bVEAzzj.png test points problem or any other? Thanks |
ATF team please help me, phone was dead after flash. customer give me short time |
br ur phone dead how????? br ashishsingh |
during flash phone dead. file was write but dont know after flash phone did not turn on |
check the partition to user area then repeat the process |
when i set partition to user area,sfotware automatically sets it boot 1 and today i am trying to repair boot now showing this i wait a lot but always show this http://i.imgur.com/gxdyW8P.png |
no answer from ATF team???????????????? |
no answer from ATF team |
still ATF team is sleeping at least tell me if there is no solution. |
I have the same problem Please atf team Solution. |
may be helpful solution from octopus jtag pro .... |
if u have toshiba emmc then needed to pulled out from board i have today handset jtage with z3x easy jtage but only this type of driver no downlaod mode Z3X EasyJtag Software ver. 2.0.7.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0B00A018B9D80701, ,FW Ver.: 01.52 CMD Pullup Level:1258 mV CMD Active Level:2186 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 110100343030303733002996114DB2FC EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0 EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 11/2015 Rev.0x0 EMMC NAME: 400073 , S/N: 697700685 EMMC NAME (HEX): 34303030373300 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: 400073_ 697700685_20160402_1521.extcsd Done. Processing file...C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin Processing file...C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin Processing file...C:\Users\ALiraza\Desktop\New folder\ROM3_J700HXXU1APA3_KLMAG2GEAC_cm.bin extCSD Are not selected , skip writing extCSD Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1258 mV CMD Active Level:2186 mV Input file : C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin Writing 0000400000 bytes to 00000000 ...ROM1 (USER ROM) Full Verify Enabled! Done. Write Speed: 449 kB/s Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1258 mV CMD Active Level:2186 mV Input file : C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done. Write Speed: 379 kB/s Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1258 mV CMD Active Level:2186 mV Input file : C:\Users\ALiraza\Desktop\New folder\ROM3_J700HXXU1APA3_KLMAG2GEAC_cm.bin Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Full Verify Enabled! Done. Write Speed: 380 kB/s every thing is done but only sec-spc210 test b/d driver needed soualtion badlyhttp://forum.gsmhosting.com/ubb/mad.gifhttp://forum.gsmhosting.com/ubb/mad.gifhttp://forum.gsmhosting.com/ubb/mad.gifhttp://forum.gsmhosting.com/ubb/mad.gifhttp://forum.gsmhosting.com/ubb/mad.gifhttp://forum.gsmhosting.com/ubb/mad.gifhttp://forum.gsmhosting.com/ubb/mad.gif |
my advices for every one for j serices always check flash files use only ugrade version not use downgrade version because some phone works after jtage and toosbaha no on poroper i think may be iam wrong |
