Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-06-2016, 08:10   #1 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
J700h boot repair problem,need help please
i am repairing boot very first time,facing problem need help please
scan Emmc here
when i try to write
here is result
test points problem or any other?
Thanks
Old 04-06-2016, 16:29   #2 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
ATF team please help me,
phone was dead after flash.
customer give me short time
Old 04-06-2016, 16:41   #3 (permalink)
ashishsingh's Avatar
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
br ur phone dead how?????
br
ashishsingh
Old 04-06-2016, 16:42   #4 (permalink)
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
br
ashishsingh
Old 04-07-2016, 06:47   #5 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
during flash phone dead. file was write but dont know after flash phone did not turn on
Old 04-07-2016, 07:53   #6 (permalink)
lemor's Avatar
Member: 38562
Thanks Meter: 1,478
check the partition to user area then repeat the process
Old 04-07-2016, 08:52   #7 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
when i set partition to user area,sfotware automatically sets it boot 1 and today i am trying to repair boot now showing this
i wait a lot but always show this
Old 04-07-2016, 16:44   #8 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
no answer from ATF team????????????????
Old 04-07-2016, 16:47   #9 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
Old 04-09-2016, 07:13   #10 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 150
still ATF team is sleeping
at least tell me if there is no solution.
Old 04-10-2016, 13:14   #11 (permalink)
Member: 1917054
Thanks Meter: 248
I have the same problem
Please atf team Solution.
Old 04-10-2016, 14:53   #12 (permalink)
saifali's Avatar
Member: 772820
Sonork: BE MASTERMIND
Thanks Meter: 124
may be helpful solution from octopus jtag pro ....
Old 04-10-2016, 15:19   #13 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 245
if u have toshiba emmc then needed to pulled out from board i have today handset jtage with z3x easy jtage but only this type of driver no downlaod mode
Z3X EasyJtag Software ver. 2.0.7.6
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0B00A018B9D80701, ,FW Ver.: 01.52
CMD Pullup Level:1258 mV
CMD Active Level:2186 mV
HiPower™ mode is ON!
eMMC Device Information
EMMC CID : 110100343030303733002996114DB2FC
EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0
EMMC Manufacturer ID: 0011 , OEM ID: 0100
EMMC Date: 11/2015 Rev.0x0
EMMC NAME: 400073 , S/N: 697700685
EMMC NAME (HEX): 34303030373300
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: 400073_ 697700685_20160402_1521.extcsd
Done.
Processing file...C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin
Processing file...C:\Users\ALiraza\Desktop\New folder\ROM3_J700HXXU1APA3_KLMAG2GEAC_cm.bin
extCSD Are not selected , skip writing extCSD
Skip loading eMMC Addon Firmware
Input file : C:\Users\ALiraza\Desktop\New folder\ROM2_J700HXXU1APA3_KLMAG2GEAC_sboot.bin
Writing 0000400000 bytes to 00000000 ...ROM1 (USER ROM)
Full Verify Enabled!
Done. Write Speed: 449 kB/s
Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 379 kB/s
Input file : C:\Users\ALiraza\Desktop\New folder\ROM3_J700HXXU1APA3_KLMAG2GEAC_cm.bin
Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM)
Done. Write Speed: 380 kB/s
every thing is done but only sec-spc210 test b/d driver needed soualtion badly
Old 04-10-2016, 15:21   #14 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 245
my advices for every one for j serices always check flash files use only ugrade version not use downgrade version because some phone works after jtage and toosbaha no on poroper i think may be iam wrong
Old 04-10-2016, 15:24   #15 (permalink)
Member: 940222
Thanks Meter: 427
http://forum.gsmhosting.com/vbb/f609...shing-2052359/
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.25261 seconds with 7 queries
