03-19-2011, 18:51 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | 5130 after flash cant ONN ATF Box FBUS Flash Started... Number of Image Files: 3 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1840020B ID DWORD 1 : 31E98C56 ID DWORD 2 : 70856D9C ID DWORD 3 : A4CCDDC9 ID DWORD 4 : 1B78473D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 19 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 2400 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : D5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 00EC Device ID : 2400 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : VAR ASIC Index : CMT 0 Certificate 3 Name : R&D ASIC Index : CMT 0 Certificate 4 Name : CCC ASIC Index : CMT 0 Certificate 5 Name : HWC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x36 (54) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:17 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.97.mcusw Total blocks to write : 1178 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:02 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_mena_a1 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 388 Entry Point: 0x00BE Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01DBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:25 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.97.ppm_mena_a1 Total blocks to write : 388 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:21 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_mena_a1_red CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 656 Entry Point: 0x00D0 Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01DC0000-0215FFFF 1 : 02160000-03FBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:51 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.97.image_mena_a1_red Total blocks to write : 656 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:33 Total Flash Write Time (Flashing Only) : 00:01:57 Total Flashing Time (Booting + Erase + Flashing) : 00:04:32 FlashInfo.RestartMode : 2 Forcing Test Mode via BUSCHECK... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1840020B ID DWORD 1 : 31E98C56 ID DWORD 2 : 70856D9C ID DWORD 3 : A4CCDDC9 ID DWORD 4 : 1B78473D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 19 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 2400 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : D5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 00EC Device ID : 2400 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... |
03-20-2011, 03:53 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | Quote:
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
how to unlock 5130 | accelr8 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-24-2010 17:52 |
