10-27-2014, 09:03 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 66
Member: 156953 Status: Offline Thanks Meter: 9 | nokia 105 ppm_ad flash file problem i cant backup ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** MCU: V 03.40 08-08-13 RM-908 (c) Nokia IMEI: **************0 Product Serial Number: F0F01F3BI Product Code : 059R452 Module Code : 0205453 Basic Production Code: 059T865 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia AD ADSP Version : p V 03.40\n08-08-13\nRM-908\n(c) NMP\nil MCU SW Version : V 03.40 08-08-13 RM-908 (c) Nokia HW Version : 2000 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED ================================================== ==== Selected VPL File: RM908_059r485_04.35_001.vpl ================================================== ==== Variant Details : Software Version : 04.35 Product Type : Product Code : Variant Version : 001 VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Reading NOR Flash: 0x00000000~0x00800000 WARNING: Invalid Data at 0x007FF800 Flash Dump Done... ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** Detected Phone Type: RM-908 MCU File Saved: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_02.700 PPM File Saved: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_02.70ad CNT File Saved: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_nai02.70ad VPL File Saved: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\RM908_059R452_02.70_001.vpl Performing Final File Checks... MCU File is OK... ERROR: PPM File is Incomplete! Deleting PPM File... CNT File is OK... Flash Files Dump Success! Total Time: 00:02:12 |
