08-17-2014, 10:49 | #16 (permalink) | |
Crazy Poster Join Date: Nov 2011
Member: 1695191 Status: Offline Thanks Meter: 42 | Quote:
instructions 1. Make sure JTAG Connection is 100% OK 2. Connect RJ-45 JTAG Cable to ATF Box 3. Connect a USB Cable to the phone DO NOT Connect BATTERY 4 wait for phone vibrate after read code | |
09-18-2014, 13:13 | #17 (permalink) |
Major Poster Join Date: Apr 2007
Member: 481573 Status: Offline Thanks Meter: 46 | Default language ID 0x040C JTAG Interface Connected, S/N 0xFFEA9DDA Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 08/07/2014 22:52:00 ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 74028353 - LOCKED PUK LEVEL 1: 40915408 - LOCKED PIN LEVEL 2: 84094272 PUK LEVEL 2: 36990937 PIN LEVEL 3: 51841469 PUK LEVEL 3: 03845140 PIN LEVEL 4: 45833543 PUK LEVEL 4: 94972424 PIN LEVEL 5: 12931002 PUK LEVEL 5: 25717793 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done! |
