Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-08-2013, 11:42   #1 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 25
Atf nitro 5130c problem
ATF Software Version v8.90
ATF Nitro FBUS Flash Started...
Number of Image Files: 3
Forcing Test Mode via BUSCHECK...
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 0F700114
ID DWORD 1 : 3C3F7F56
ID DWORD 2 : 919BE052
ID DWORD 3 : FE36248C
ID DWORD 4 : D4DF705A
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 02
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 03
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
OLD Protocol Detected... Using Turbo Mode...
Pabub KEY Request
No PAPUBKeysHash Returned
Scanning Simlock Applet Type...
OK
PA_SL3 Applet detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 02
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\354223036488773\3542230364887 73_51303.rpl
Processing Image File :
C:\Documents and Settings\BARUGA\Desktop\RM-495V7.98\RM-495 V 7.98\rm495__07.98.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1178
Entry Point : 0x5057
Page Format : 128K
Maximum Page Size : 0x00004000
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 02
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
STATUS_REQUEST_BB5...
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:00:01
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm495__07.98.mcusw
Total blocks to write : 1178
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:54
C:\Documents and Settings\BARUGA\Desktop\RM-495V7.98\RM-495 V 7.98\rm495__07.98.ppm_x
CMT Type : BB5
Number of Blocks : 494
Entry Point : 0x00BE
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:37
Processing : rm495__07.98.ppm_x
Total blocks to write : 494
Flashing FAILED
BB5_WRITE_FlashFile_0
Go to Settings -->
Nokia Settings -->
FBUS DDR&2TX Synchronization Timeout
Change the current value selected to a higher value
and Restart AdvanceBox.exe software to apply it
Operations Failed....
THEN HERE IT CAN'T POWER ON.
HEHP PLEASE
BARUGA
Old 03-08-2013, 12:39   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Update to latest version - http://forum.gsmhosting.com/vbb/9231321-post50.html
Auto update to V9.61
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 03-08-2013, 16:31   #3 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 25
thanx the update has solved the problem.
Old 12-05-2013, 08:40   #4 (permalink)
Member: 1228041
Thanks Meter: 11
Number of Image Files: 4
C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\RM-495\rm495__07.97.mcusw
CMT Type : BB5
Page Format : 128K
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
ID DWORD 0 : 27E00101
ID DWORD 1 : 0E8E0056
ID DWORD 2 : 7E7FA2DA
ID DWORD 3 : C5A67B49
ID DWORD 4 : 7F2F6CEB
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum FD
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 2400 -> Type not in database
Revision ID : 8A31
Block Length : 13
Device Index : 00
Device Contents : FFFFFFFFFFFFFFFFFFFF
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : E5
SendAlgoCode_DCT5..
Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 2400
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
dis type err coming ple help me
Page generated in 0.22698 seconds with 8 queries
