lumia 610 eMMC unlock error Hi, I want to unlock lumia 610 but I got this error "out of memori" after "Dumping AMSS FAT16 Region" going to 100%. I wrote the osbl qcom with TP eMMC methode before. Any sugestion ? |
Hi, lumia 505, 510 and 610 unlocking via JTAG and NOT via eMMC. JTAG = ATFJ.exe software and JTAG Pinouts given by ATF JTAG software. eMMC = AdvanceBox.exe->Windows Phones Tab-> TP Service. So you should use ATFJ.exe in order to UNLOCK Lumia 505, 510 and 610 Your box must be activated for ATF JTAG Module in order to use ATFJ.exe BR |
"[WP7 eMMC Direct] * Added PERMANENT UNLOCK for WP7 Phones Unlocked via PIN or PUK Codes (Disable RE-Locking) Supported Models: Lumia 800 - Qualcomm OSBL must be written to phone first (via USB Flashing) Lumia 800C - Qualcomm OSBL must be written to phone first (via USB Flashing) Lumia 710 - Qualcomm OSBL must be written to phone first (via USB Flashing) Lumia 610 - Qualcomm OSBL must be written to phone first (via JTAG or eMMC TP) Lumia 610C - Qualcomm OSBL must be written to phone first (via JTAG or eMMC TP) Lumia 510 - Qualcomm OSBL must be written to phone first (via JTAG or eMMC TP) Lumia 505 - Qualcomm OSBL must be written to phone first (via JTAG or eMMC TP) * Added Restore DLOAD to Lumia 610 * Added Restore DLOAD to Lumia 610C I think this was what I misunderstud... |
@eliberatoro: Added PERMANENT UNLOCK for WP7 Phones Unlocked via PIN or PUK Codes (Disable RE-Locking) This means phone that was unlocked before via PIN / PUK code can be permanent unlock via ATF Software. For example: Lumia 710 and 800 can unlock via ATF software after you write OSBL QCOM and unlock via eMMC Direct, PIN / PUK code becomes 8 and 10 times ZEROs. But, this isn't PERMANENT UNLOCK, flashing will RE-LOCK these 710 and 800. In order to PERMANENT UNLOCK, you need OSBL QCOM again and Disable Re-Locking from eMMC Direct Tab. This is for 710 and 800 only. Now if you have got lumia 505, 510 and 610, there is only way to unlock is via ATF JTAG software or online network codes, and same flashing will RE-LOCK them even buy codes or unlock via JTAG. In order to PERMANENT UNLOCK, you need OSBL QCOM, like said in Release Notes: (Qualcomm OSBL must be written to phone first (via JTAG or eMMC TP)) Then you can use Disable RE-Locking and it will be permanent unlocked. Hope this helps. BR |
Now it is clear :). I activated the JTAG and I have two 610 to play with them. Thanks ! |
