Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-23-2013, 07:11   #1 (permalink)
Member: 90761
Sonork: 1617079
Thanks Meter: 95
bugs flash asha 205 - [NO BUG - YOU HAVE USED WRONG FILES]
after flash with atf, phone goes contact service. and fix by other dongle. not for compare bro. only sugestion for fix this bug for atf team
12:56:58 : ================================================
12:56:58 : Basic Phone Information
12:56:58 : MCU Version: V 03.19 25-12-12 RM-863 (c) Nokia
12:56:58 : IMEI Plain : 12345610654321?
12:56:58 : IMEI Spare : A123456106543210
12:56:58 : IMEI SV : 31234561065432106F
12:56:58 : Phone Model: J 205
12:56:58 : Category : Phone
12:56:58 : Phone Type : RM-863
12:56:58 :
12:56:58 : Extended Phone Information
12:56:58 : Product Serial Number: DDD6045AH
12:56:58 : Product Code : 059Q092
12:56:58 : Module Code : 0205222
12:56:58 : Basic Production Code: 059N267
12:56:58 : Long Production SN : 0
12:56:58 : PPM SW Version : V 03.19 25-12-12 RM-863 (c) Nokia X
12:56:59 : BT MCM Version : 19b5-22012
12:56:59 : MCU SW Version : V 03.19 25-12-12 RM-863 (c) Nokia
12:56:59 : HW Version : 1000
12:56:59 : RFIC Version : 68
12:56:59 : LCD Version : TPO
12:56:59 : Content Pack Version : Content: x_059Q0P4 V 03.19 25-12-12 RM-863 (c) Nokia
12:56:59 : Bluetooth ID : 00:02:5B:00:A5:A5
12:56:59 : CS Type : GSM900, GSM1800
12:56:59 :
12:56:59 : ********** SIMLOCK INFO **********
12:56:59 : CONFIG_DATA : 0000000000000000
12:56:59 : PROFILE_BITS : 0000000000040000
12:56:59 : ASIC : 11
12:56:59 : PROVIDER : Unknown Provider
12:56:59 : LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
12:56:59 :
12:56:59 : Unable to read SP Data..
12:56:59 :
12:57:00 : SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
12:57:00 : SIMLOCK_TEST : PASSED
12:57:00 : SECURITY_TEST : FAILED
12:57:00 : > Try SX4 "PM AUTH"
12:57:00 : > Then Write PM 1 and 309
12:57:00 : SECURITY_CODE : 35816
12:57:00 : PHONE_MODE : TEST
12:57:00 :
12:57:00 : ================================================
12:57:00 : Dynamic Camera Configuration
12:57:00 : DCC ID : NI00CS00000401022F03
12:57:00 : DCC Ver: 010009
12:57:00 : Status : OK
12:57:00 :
12:57:00 :
done by other dongle
Reading Phone Info....
Connected phone - 205
Software ver : V 03.19 25-12-12 RM-863 (c) Nokia
IMEI : 12345610654321?
XappVer : 0000067C
PPM : V 03.19 25-12-12 RM-863 (c) Nokia X
CNT : Content: x_059Q0P4 V 03.19 25-12-12 RM-863 (c) Nokia
Product SN : DDD6045AH
Product code : 059Q092
Base Prd.code: 059N267
Module code : 0205222
Long Prod.SN : 0
Hardware info=======
HWID : 1000
Batery: 4626 mV
CMT BT: 19b5-22012
LCDVer: TPO
Lock info ===========
IMEI spNet : 1A 32 54 16 60 45 23 01
IMEI svNet : 13 32 54 16 60 45 23 01 F6
Sl Conf : 000-00-00000000000
Sl Prof : 000000000004000-0
Sl Aux : 000B0000
Hw Sig : DDA23DA8A755C68D
Country : Unknown
Operator : Unknown
Lock info:
IMEI DAMAGED!!! CRT308 save skipped...
CMLA Key status : Ok
SimLock status : Ok
Security status : Damaged!!!!!
PA_SimLock Version :
PA_SL30 (20 digit) phone detected...
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Set phone in Normal mode...
Restarting...
Done!
Connect phone on selected interface...
Core : v1.66 , BB5XG FlashEngine : v5.3
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm862__03.19.mcusw
PPM : rm862__03.19.ppm_x
CNT : rm862__03.19.image_x_059Q092
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.55_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
===Flashing [MCU]===
File : rm862__03.19.mcusw
Image : rm862__03.19.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:02
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x017C0000
Erasing, wait ...
Erase done, time : 00:02:06
Write , Start : 0x40280000 , Len : 0x017C0000
Flashing , wait ...
Region flash done, time : 00:00:48
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
File : rm862__03.19.ppm_x
Image : package_x.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A40000 , Len : 0x00640000
Erasing, wait ...
Erase done, time : 00:00:28
Write , Start : 0x41A40000 , Len : 0x00551064
Flashing , wait ...
Region flash done, time : 00:00:10
===Flashing [CNT]===
File : rm862__03.19.image_x_059Q092
Image : package_x_059Q092.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42080000 , Len : 0x01DA0000
Erasing, wait ...
Erase done, time : 00:03:05
Write , Start : 0x42080000 , Len : 0x00FE0000
Flashing , wait ...
Region flash done, time : 00:00:31
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:07:26
Reboot phone now...
Software Info: V 03.19 25-12-12 RM-862 (c) Nokia
IMEI: 353698055804128
PPM version : V 03.19 25-12-12 RM-862 (c) Nokia X
Product code: 059Q092
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
AfterFlash operations done ;D
Done!
Elapsed: 00:08:09
Phone found!
Series 40 Device detected!
read info... - Ok
Software ver : V 03.19 25-12-12 RM-862 (c) Nokia
IMEI 1 : 353698055804128
IMEI 2 : 353698055804136
XappVer : 0000067C
PPM : V 03.19 25-12-12 RM-862 (c) Nokia X
CNT : Content: x_059Q092 V 03.19 25-12-12 RM-862 (c) Nokia
Long Prod.SN : 0
HWID : 1000
Batery: 4621 mV
CMT BT: 19b5-22012
LCDVer: TPO
IMEI : 353698055804128
IMEI spNet : 3A 35 96 08 55 08 14 02
IMEI svNet : 33 35 96 08 55 08 14 02 F6
Sl Conf : 001-01-00000000000
Sl Prof : 800000000004000-B
Sl Aux : 000B0000
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
CRT308 Backup Created
SimLock status : Ok
Security status : Ok
User Code : 12345
Done!
Old 07-23-2013, 09:59   #2 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
ATF have no Bug for Flashing Nokia 205/206 Model,
See Your Flash Logs You Only Can find What is Wrong in it,
Your Phone is
Product Type:
RM-862
Handset:
Nokia Asha 205 DS
Product Code:
059Q092
When You Flash Using |ATF u have selected Wrong Product Type (RM-863)
Thats only the thing You Got CS after flash! reflash with RM-862 ,
its will FIx it.
When You FLashed with Other Tool there was you Selected Correct Product Type, anyway Next time you do careful ,
Old 07-23-2013, 15:37   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
@ ekel
We always accept positive report from our users , it may be a BUS , But in your case you you should correct yourself 1st then advice to us .
You have flash with wrong flash file with ATF .
Br - srinibas
Old 04-23-2014, 12:42   #4 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
Your Phone is
Product Type:
RM-862
Handset:
Nokia Asha 205 DS
Product Code:
059Q092
its will FIx it.
What About Latest firmware 4.17 Are U TEST ??????????????????????
Old 03-13-2015, 11:21   #5 (permalink)
Member: 1705678
Sonork: 100.1642494
Thanks Meter: 2
MXKEY [FT SCR2000 0], SN:
Using device: USB ROM
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.117
Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsucx64\Nokia USB Flashing Generic (), PORT_ID: 37FA3E37
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.55
EBL version: Quantum_Bootloader_10.55_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35669505194168
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35669505194168_ back.RPL)
Processing file: DB0F0280_rm862__03.19_2.mcusw
Downloading item CODE:rm862__03.19.mcusw_ebl_psi.fls, num block: 4, size: 25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.359 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.544 s
Erasing area 0x40280000-0x41A3FFFE ...OK
Programming completed in 33.696 s
Checksum verified (0x12D7)
Processing file: 0C43A11F_rm862__03.19_2.ppm_x
Downloading item CUSTackage_x.ppm_ebl_psi.fls, num block: 1, size: 5.32 MB
Erasing area 0x41A40000-0x41F91062 ...OK
Programming completed in 7.566 s
Checksum verified (0x2C31)
Processing file: 70596DC3_rm862__03.19.image_x_059Q092
Downloading item CUSTackage_x_059Q092.image.fls, num block: 1, size: 15.88 MB
Erasing area 0x42080000-0x43E1FFFE ...OK
Programming completed in 25.444 s
Checksum verified (0x8ADD)
Total time for flashing process(boot+erase+write) was 4 min 59.064 s
Waiting for USB device removal ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 03-13-2015, 11:22   #6 (permalink)
Member: 1705678
Sonork: 100.1642494
Thanks Meter: 2
CPU: GenuineIntel, Sp: 5
Platform: Windows NT 6.1 (Build 7600 )
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Current Paths:
EXE : C:\Program Files (x86)\Nokia\Phoenix
TESLA: C:\Wintesla\
DCT3 : C:\Program Files (x86)\Nokia\Phoenix\Flash3\
DCT4 : C:\Program Files (x86)\Nokia\Phoenix\Flash\
BB5 : C:\Program Files (x86)\Nokia\Phoenix\Flash\
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007. Sn: 81580
HID: F91C0DE74260004A, HWK: A1.04-PRO1
Features: 00000001
Licence: True
LogFile: .\_!_LOG\81580_13032015_165925_LOG.txt
Insert USB Cable to Switched OFF Phone and Power ON
IF_USB: XGOLDxxx
IF_SBL: XGOLD213, Ok
IF_EBL: Quantum_Bootloader_10.55_M1S1 10.55, Mode: CC
FL_ID : EC001230, Samsung K5N1258ACM 512Mb
MCU FLASH BUNDLE: rm862__04.51.mcusw
Flash File: rm862__04.51.mcusw_ebl_psi.fls
Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00
Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00
Erase Area: 0x40040000 - 0x4005FFFE, Erased: 00:00
Write Area: 0x40040000 - 0x4005FFFE, Written: 00:00
Erase Area: 0x40060000 - 0x4015FFFE, Erased: 00:02
Write Area: 0x40060000 - 0x4015FFFE, Written: 00:02
Erase Area: 0x40280000 - 0x41A3FFFE, Erased: 00:49
Write Area: 0x40280000 - 0x41A3FFFE, Written: 00:47
Erase Area: 0x43E20000 - 0x43E5FFFE, Erased: 00:00
PPM FLASH BUNDLE: 0C43A11F_rm862__03.19_2.ppm_x
Flash File: package_x.ppm_ebl_psi.fls
Erase Area: 0x41A40000 - 0x4207FFFE, Erased: 00:11
Write Area: 0x41A40000 - 0x41F91062, Written: 00:10
CNT FLASH BUNDLE: 70596DC3_rm862__03.19.image_x_059Q092
Flash File: package_x_059Q092.image.fls
Erase Area: 0x42080000 - 0x43E1FFFE, Erased: 00:34
Write Area: 0x42080000 - 0x4305FFFE, Written: 00:31
Erase Area: 0x43E60000 - 0x43F3FFFE, Erased: 00:00
Flashing Done: 03:15
ShutDown Done
All Done, Time: 03:48
** User Break **
IF_USB: XGOLDxxx
Erase Area: 0x40280000 - 0x41A3FFFE, Erased: 00:50
PPM FLASH BUNDLE: rm862__04.51.ppm_x
Write Area: 0x41A40000 - 0x41FA4C4A, Written: 00:10
CNT FLASH BUNDLE: rm862__04.51.image_x_059Q092
Erase Area: 0x42080000 - 0x43E1FFFE, Erased: 00:33
Flashing Done: 03:16
ShutDown Done
Page generated in 0.23634 seconds with 8 queries
