02-28-2013, 05:59 | #1 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | lumia 800 cannot be unlocked... kindly check <<< SOLVED >>> Quote:
the phone is still asking for pincode and when i try to enter 8 zeroes it does not accept the code... help pls! thanks! btw this is not my first time to unlock lumia 800 i've done few units already and it went smoothly... | |
02-28-2013, 06:10 | #2 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | this is what i get if i try to unlock it via testpoint.. 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 04470000 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:05 |
02-28-2013, 06:18 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Find your solution here - http://forum.gsmhosting.com/vbb/f609...tions-1127479/ Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
02-28-2013, 06:22 | #5 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 791635 Status: Offline Sonork: 100.1611665 Thanks Meter: 30 | Flash your phone with latest available version and unlock again afterwards. 100% tested by me. |
The Following User Says Thank You to Mobilefather For This Useful Post: |
02-28-2013, 06:25 | #6 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | i havent tried flashing yet.. mislooked the buttom part of the FAQ.. will try to flash it and unlock it again... will post result! thanks for the replies.. br |
02-28-2013, 08:00 | #8 (permalink) | |
Member: 4021 Status: Offline Thanks Meter: 782 | Quote:
finally unlocked!! thanks for the replies! br | |
