Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: Slovakia Age: 41
Member: 13922 Status: Offline Thanks Meter: 333 | Lumia 800 can't unlock - [SOLUTION INSIDE ATF 9.12] I tried to flash 2different FW's from NAVIFIRM but with still same result my wirres are realy short any idea? here is log: Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 0F4A237F Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:06 |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @SPUnlock_SK ERROR: Dump Aborted, Too much CRC Failures! This means TP Connection or TP Wires are NOT STABLE. So try to make your wires shorter (maximum 5 inches for the 0.10mm gauge coated copper wire). Also check this post: http://forum.gsmhosting.com/vbb/f609...819-a-1540417/ |
The Following User Says Thank You to Advance-Box For This Useful Post: |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: R BiH Age: 48
Member: 68842 Status: Offline Thanks Meter: 9 | hi i have 2 inches cable from atf box to tp,i have flashed phone with version firmware that you specified,changing 3 diff. laptops but always stupid crc error |
![]() | #6 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2000
Member: 2145 Status: Offline Thanks Meter: 36 | ![]() Hello First of all want to say thanks to X-Shadow and all ATF team for so Great research =) Concerning unlocking pb. There is no problem with old PC , PC OS, bad soldering, wrong tp or fw inside lumia. Probably i'm wrong , but i think that problems appear only with this Toshiba eMMC chip. = Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 = You can find more info about this pb here http://forum.gsmhosting.com/vbb/f609...ml#post8769409 http://forum.gsmhosting.com/vbb/f609...5/#post8769319 http://forum.gsmhosting.com/vbb/f609...oblem-1537145/ http://forum.gsmhosting.com/vbb/f609...nlock-1540442/ One of mentioned links contain solution for unlock in way to combine atf tp with other product, at least as temporarily solution for unlockers. Also I have played with Lumia with HYNIX chip on board (Manufacturer ID: 90 Application ID : 014A) and all went fine. Boot repair and unlocking too. But I want to warn users do not use Boot repair with MBR rewrite ticked if it is not necessary for eMMC Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Cause at end with high probability you will have dead phone in hands. Maybe I'm wrong ( and it would be good if so ), but by my opinion MBR areas contain different data for HYNIX and Toshiba chips. RGDS VIK |
The Following 3 Users Say Thank You to VIK For This Useful Post: |
![]() | #7 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
WOW... You really hit the bull's eye with your post! TOSHIBA eMMC Chips is BLOCKED by ATF BOX because I assumed that TOSHIBA eMMC is only for 610 and 610C phones. Everytime ATF BOX "sees" a TOSHIBA Manufacturer ID: 11, it will disable proper eMMC dump so that end users will NOT BE TEMPTED to try and unlock 610 phones. You will NOT have "dead" phones in hand though, because only eMMC READ is disabled. eMMC Write is working like it is for the rest of the Manufacturer IDs. I REALLY appreciate your post and admire the fact that you helped me solve this problem among other end users. I will put up a "quick software update" to bypass ATF BOX rejection of this eMMC. BEST REGARDS! X-Shadow | |
![]() | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @SPUnlock_SK @VIK The Problem is already solved by ATF Software 9.12. For More Information, please check this post: http://forum.gsmhosting.com/vbb/8781750-post239.html B.R. |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! I am facing this problem on lumia 800 and its TOSHIBA Flash Chip and check again and again connections are ok and phone get dead during unlock process please help me what to do now .... while a unlock lumia 800 successfully |
![]() | #11 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Before it was giving error like this 09:18:59 : ================================================== ==== 09:18:59 : ================================================== ==== 09:18:59 : Lumia Test Point Connection Module 09:18:59 : ================================================== ==== 09:18:59 : ================================================== ==== 09:18:59 : 09:18:59 : 1. DO NOT USE THE PHONE"S BATTERY 09:18:59 : 2. Connect the Soldered TP Connections to ATF Box 09:18:59 : 3. Disconnect the USB Cable and Wait until the 09:18:59 : the ATF Software will tell you to Connect the USB. 09:18:59 : 09:19:04 : 09:19:04 : Interface Reset OK! 09:19:04 : Reading Platform Information... 09:19:04 : Selecting Active Handle... 09:19:04 : Select Handle OK! 09:19:04 : Sending Ping... 09:19:04 : Ping Reply OK! 09:19:04 : 09:19:04 : 09:19:04 : Storage Device Information 09:19:04 : Manufacturer ID: 03 09:19:04 : Application ID : FFFF 09:19:04 : Product Name : ÿÿÿÿÿÿ 09:19:04 : Product Rev : FF 09:19:04 : Product SN : FFFFFFFF 09:19:04 : 09:19:04 : Protection Information 09:19:04 : Write Protect A: OFF 09:19:04 : Write Protect B: OFF 09:19:04 : 09:19:05 : 09:19:05 : Dumping AMSS FAT16 Region 09:19:05 : Please wait for 2-4 Mintues... |
![]() | #12 (permalink) |
Member: 13922 Status: Offline Thanks Meter: 333 | with new update I was facing some differnet connection problems 09:17:48 : ================================================== ==== 09:17:48 : ================================================== ==== 09:17:48 : Lumia Test Point Connection Module 09:17:48 : ================================================== ==== 09:17:48 : ================================================== ==== 09:17:48 : 09:17:48 : 1. DO NOT USE THE PHONE"S BATTERY 09:17:48 : 2. Connect the Soldered TP Connections to ATF Box 09:17:48 : 3. Disconnect the USB Cable and Wait until the 09:17:48 : the ATF Software will tell you to Connect the USB. 09:17:48 : 09:18:12 : 09:18:12 : ERROR: Phone WAS NOT Detected! 09:18:12 : Check the BLUE WIRE Connection 09:18:12 : Check the GREEN WIRE Connection ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: Phone WAS NOT Detected! 0x01 Check your Test Point Soldering! even all TP's are solder OK I checked 2times, with 2different cables now after few tried my Lumia 800 with toshiba eMMC can't power on how can I make it alive? |
![]() | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Your problem is related to your soldering. Other people who I sent PM about the 9.12 TOSHIBA fix already confirmed that their phones were already unlocked by 9.12. You should also expect the same fate for you phone. Check properly the GREEN and BLUE TP resistors. Make sure you soldered in the correct side. If phone does not power ON, then try to remove you TP connections first... Then : 1. Press power button for 12 seconds 2. Release power button for 3 seconds 3. Press power button for 2 seconds or until you feel a short 200 ms vibration |
![]() | #15 (permalink) | |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | Quote:
The problem is the resistor at blue tp, If it is broken or desold the set with Toshiba chip ,will not connect,and also ll not turn on. Today i faced same problem,and after properly soldring this resistor the set unlocked and working. If this resistor is broken in lumia with chip other than Toshiba,the set is unlocked and also working fine. Wr KHAWAR | |
