10-06-2012, 07:26 | #17 (permalink) |
Temporary banned !! Join Date: Apr 2008 Location: philippines
Member: 741567 Status: Offline Thanks Meter: 9 | i have same problem like with spunlock error connection with green and blue wire although its connected properly maybe broken resistor is causing my headache too maybe somebody can tell where we can find replacement for that damage tp resistors thanks |
12-01-2012, 07:58 | #20 (permalink) |
Freak Poster Join Date: Jul 2006 Location: india
Member: 306087 Status: Offline Thanks Meter: 24 | lumia 800 unlock done ok ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 498808A7 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:35:32 ony thing is u need proper cable shoter u can make start all ok cheers |
12-19-2012, 21:11 | #21 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Algeria Age: 41
Member: 851061 Status: Offline Sonork: 100.1613359 Thanks Meter: 25 | Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 04E25A34 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:53 |
01-09-2014, 13:33 | #23 (permalink) |
Junior Member Join Date: Sep 2010 Location: ernamkulam
Member: 1397614 Status: Offline Thanks Meter: 1 | Lumia 800 net work unlocking LUMIA 800 NETWORK UNLOCKING ATF CONNECT TP BB5 PORT & USB MICRO USB OG 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. 4' CONNECT TEST POINTS THEN CONNECT USB Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 90014A48594E4958205C00215B7C CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 800/800C Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.12 Product SN : 00215B7C Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Dumping Custom Region Please wait for some time... Partition Selected: USER AREA (eMMC Clock 15000000 Hz) Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:37 Last edited by ajeshkb; 01-09-2014 at 13:39. |
