11-20-2013, 09:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | nokia 301 rm-839 successfully flashed with atf here is full logs Code: Number of Image Files: 3 Code: Processing Image File : rm839__02.33.mcusw Processing Image File : rm839__02.33.ppm_m2 Processing Image File : rm839__02.33.image_m2_059Q9B5_059T111_212_01 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F01650A9070100030101E0001809100474514A3891B6FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: E000180910047451-4A3891B6 Original Product Code: 059T111 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355516058746948\355516058746948_13135.rpl Current File : rm839__02.33.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm839__02.33.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 Erase Block: 0x00090000~0x000A0FAE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x60000000~0x6003FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x02 Erase Block: 0x60040000~0x600403FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x03 Erase Block: 0x62E00000~0x63D0520E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xFFF00000~0xFFF7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Processing Data Block 0x04 Erase Block: 0x80000000~0x80C1B3CA Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x05 Erase Block: 0x62080000~0x620C3FFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x06 Erase Block: 0x63F79C00~0x63FC046E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x07 Erase Block: 0x61F00004~0x6204547A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm839__02.33.ppm_m2 Number of Images: 1 package_m2.ppm_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x80F00000~0x81420D2E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm839__02.33.image_m2_059Q9B5_059T111_212_01 Number of Images: 1 rm839__02.33.image_m2_059Q9B5_059T111_212_01.fls Processing Data Block 0x00 Erase Block: 0xA1000000~0xA296BBFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xAE000000~0xAE2FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:00:13 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 02.33 17-05-13 RM-839 (c) Nokia IMEI Plain : 355516058746948 IMEI Spare : A355516058746940 IMEI SV : 33555160587469406F IMEI (2nd) : 355516058746955 IMEI Spare : A355516058746950 IMEI SV : 33555160587469506F Phone Model: Nokia 301 Dual SIM Category : Phone Phone Type : RM-839 ================================================ Extended Phone Information ================================================ Product Serial Number: 0E63F89BH Product Code : 059T111 Module Code : 0205266 Basic Production Code: 059P5R3 Long Production SN : 0 PPM SW Version : V 02.33 17-05-13 RM-839 (c) Nokia M2 BT MCM Version : 19e2-4702G12 ADSP Version : PMU_MAXIM8939B MCU SW Version : V 02.33 17-05-13 RM-839 (c) Nokia HW Version : 1000 UEM Version : 18 UPP Version : MFR:0x20,DEV:0x40,REV:0x131 RFIC Version : 152 LCD Version : TPO Camera : 01035602006004 Content Pack Version : Content: m2_059Q9B5 V 02.33 17-05-13 RM-839 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : F4:F5:A5:74:E9:38 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** ERROR : Unable to read Simlock Info ... Maybe you are reading BB5 phone ... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 02.33 17-05-13 RM-839 (c) Nokia IMEI Plain : 355516058746948 IMEI Spare : A355516058746940 IMEI SV : 33555160587469406F IMEI (2nd) : 355516058746955 IMEI Spare : A355516058746950 IMEI SV : 33555160587469506F Phone Model: Nokia 301 Dual SIM Category : Phone Phone Type : RM-839 ================================================ Extended Phone Information ================================================ Product Serial Number: 0E63F89BH Product Code : 059T111 Module Code : 0205266 Basic Production Code: 059P5R3 Long Production SN : 0 PPM SW Version : V 02.33 17-05-13 RM-839 (c) Nokia M2 BT MCM Version : 19e2-4702G12 ADSP Version : PMU_MAXIM8939B MCU SW Version : V 02.33 17-05-13 RM-839 (c) Nokia HW Version : 1000 UEM Version : 18 UPP Version : MFR:0x20,DEV:0x40,REV:0x131 RFIC Version : 152 LCD Version : TPO Camera : 01035602006004 Content Pack Version : Content: m2_059Q9B5 V 02.33 17-05-13 RM-839 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : F4:F5:A5:74:E9:38 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 006004 Status : OK ====================================================== Selected VPL File: RM839_059T111_02.33_008.vpl ====================================================== Variant Details : RM-839 VAR MEA-M2 PK CV BLACK Software Version : 02.33 Product Type : RM-839 Product Code : 059T111 Variant Version : 008 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK thanks atf box br S.M.JUNAID |
The Following 5 Users Say Thank You to r-jcomm For This Useful Post: |
11-20-2013, 09:59 | #2 (permalink) |
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | if any one face problem in flashing then download this driver Asha after download extract to ur desktop then open folder asha>xp and run winusb.exe after install this package restart ur pc and u r done br S.M.JUNAID |
The Following 2 Users Say Thank You to r-jcomm For This Useful Post: |
