08-02-2013, 12:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Lumia 800 unlock problem 14:32:19 : ================================================== ==== 14:32:19 : ================================================== ==== 14:32:19 : * * * *eMMC Test Point Connection Module * * * * * ** 14:32:19 : ================================================== ==== 14:32:19 : ================================================== ==== 14:32:19 : * * * * * * * * * * * * * * * * * * * * * * * * * * ** 14:32:19 : 1. DO NOT USE THE PHONE"S BATTERY * * * * * * * * * ** 14:32:19 : 2. Connect the Soldered TP Connections to ATF Box * ** 14:32:19 : 3. Disconnect the USB Cable and Wait until the * * * * 14:32:19 : * *the ATF Software will tell you to Connect the USB.* 14:32:19 : * * * * * * * * * * * * * * * * * * * * * * * * * * ** 14:32:21 :* 14:32:21 : Interface Reset OK! 14:32:21 : eMMC Supported Voltage Range: 14:32:21 : 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V 14:32:21 :* 14:32:21 : eMMC Boot Information 14:32:21 : BOOT PARTITION * *: USER AREA 14:32:21 : PARTITION ACCESS *: R/W USER PARTITION 14:32:21 : PERM_BOOT_CFG_PROT: DISABLED 14:32:21 : PWR_BOOT_CFG_PROT : DISABLED 14:32:21 : eMMC FirmW UPDATE : DISABLED 14:32:21 :* 14:32:21 : Lumia 800/800C Detected 14:32:21 :* 14:32:21 : eMMC Device Information 14:32:21 : Manufacturer ID: 90 14:32:21 : Device Type * *: Embedded BGA 14:32:21 : Application ID : 4A 14:32:21 : Product Name * : HYNIX* 14:32:21 : Product Rev * *: 5.12 14:32:21 : Product SN * * : 0019248A 14:32:21 : Manufactured * : January 2011 14:32:21 :* 14:32:21 : Card Specific Data 14:32:21 : CSD_STRUCTURE * * : Extended 14:32:21 : SPEC_VERS * * * * : Version 4.1/4.2/4.3 14:32:21 : TAAC * * * * * * *: 300 ns 14:32:21 : TRANS_SPEED * * * : 4000000 KHz 14:32:21 : READ_BL_LEN * * * : 512 Bytes 14:32:21 : C_SIZE * * * * * *: HIGH CAPACITY 14:32:21 : WP_GRP_ENABLE * * : YES 14:32:21 : WRITE_BL_LEN * * *: 512 Bytes 14:32:21 : CONTENT_PROT_APP *: NO 14:32:21 : PERM_WRITE_PROTECT: NO 14:32:21 : TMP_WRITE_PROTECT : NO 14:32:21 :* 14:32:21 :* 14:32:21 : Dumping Custom Region 14:32:21 : Please wait for some time... 14:32:21 : Partition Selected: USER AREA 14:32:21 : (eMMC Clock 15000000 Hz) 14:32:49 : Patch Bit Found... 14:32:49 : Total Patch Bits Found: 1 14:32:49 : Patching AMSS... 14:32:50 : Patch OK! 14:32:50 :* 14:32:50 : SP Unlock Done! 14:32:50 :* 14:32:50 : PIN: 00000000 14:32:50 : PUK: 0000000000 14:32:50 :* 14:32:50 : Total Elapsed Time 00:00:33 ================================================== ==== ================================================== ==== now eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 800/800C Detected eMMC Device Information Manufacturer ID: 90 Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.12 Product SN : 0019248A Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Dumping Custom Region Please wait for some time... Partition Selected: USER AREA (eMMC Clock 15000000 Hz) WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Last edited by juve2106; 08-02-2013 at 12:31. |
