Lumia 800 Patch Bit NOT FOUND! <<< SOLVED >>> Hi i try to unlock one Nokia Lumia 800 locked after do all step i get this : ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000080000000 4D00000001000000E80300000000000046000000E9030000B8 0B0000000000000C000000A10F0000E0930400000000000500 000081A304007F1CD50155AA3DEBBFFF Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 001A60F2 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:03:58 How to fix this :confused: |
Read this thread , solution posted - http://forum.gsmhosting.com/vbb/f609...tions-1127479/ Br - srinibas |
i have the same problem here. and i v excluded atf from my anti-virus. but still same problem 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000080000000 4D00000001000000E80300000000000046000000E9030000B8 0B0000000000000C000000A10F0000E0930400000000000500 000081A304007F5CD60155AAB75FBFFF Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 5590667D Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:04:42 |
After flash Unlock Done! ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 800/800C Detected eMMC Device Information Manufacturer ID: 90 Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.12 Product SN : 001A60F2 Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Dumping Custom Region Please wait for some time... Partition Selected: USER AREA (eMMC Clock 15000000 Hz) Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:37 Thank you for help :D |
