04-15-2014, 18:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia norten-caucasus Age: 52
Member: 18234 Status: Offline Thanks Meter: 97 | Please help support plz look my info 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056335730304D0075EC33C8 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.x (For MMC v4.x) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB ERROR: EMMC_SEND_EXT_CSD FAILED (CMD8+) Check GREEN Test Point Connection What is the problem and how to solve this problem |
04-16-2014, 15:18 | #2 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Aurangabad Maharashtra
Member: 1670311 Status: Offline Sonork: 431001 Thanks Meter: 6 | having problem in bb5 and infineon with atf n73 successfully connect with hwk here is log MCU SW : V 05wk47v62 05-12-08 RM-133 (c) Nokia. APE Core: V 4.0850.43.0.1 12-12-2008 RM-133 APE Var : V 4.0850.43.0.1-12 12-12-2008 RM-133 Product : Nokia N73 Prd.Code: 0543843 Bpr.Code: 0537044 Prod.Sn : CDE012847 HW Vers : 7200 APE HW : 1 APE Adsp: 256 EM VILMA: 15 EM BETTY: 22 RFIC Ver: 17211721 DSP Vers: scarfe_mc.05wk46v50p2 IMEI : 358973-01-403093-2 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 000-00-00000000000 SL Prof : 0142196F00000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found set on a contact retailer i wanted to all test pass plz help and second thing is in infineon when going to bus chek after lilbit atf goes hang plz plz plz help atf team |
04-16-2014, 16:55 | #3 (permalink) | |
Member: 18234 Status: Offline Thanks Meter: 97 | Quote:
