Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-26-2014, 16:28   #1 (permalink)
Member: 85467
Thanks Meter: 104
Nokia 710 driver?
hy
how install driver for nokia 210, run all driver from support, also manual update driver but "cannot install this hardware"
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 1220100225122829
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356326050109130\3563260501091 30_62047.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356326050109130\3563260501091 30_CERTIFICATE_0FE357D3.bin
Infineon USB Buscheck Done
Phone Restart Mode: TEST MODE
Process Done...
Scanning USB Ports...
ERROR: Active Phone Handle was NOT DETECTED
TIP: Make sure that Phone USB Connection Mode is
OVI Suite Mode
or
PC Suite Mode
ERROR: Read Phone Failed!
thx
Old 05-26-2014, 17:37   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Give this path: "C:\AdvanceBox Turbo Flasher\Drivers\Lumia and asha phones drivers
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 05-26-2014, 18:41   #3 (permalink)
Member: 85467
Thanks Meter: 104
done, but "cannot install this hardware"
thx
Old 05-27-2014, 07:58   #4 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
thx
What is your PC OS type ?
Br - srinibas
Old 05-27-2014, 10:24   #5 (permalink)
Member: 643472
Sonork: 100.96901
thx
1. C:\AdvanceBox Turbo Flasher\Driver\Nokia_Connectivity_Cable_Driver_7.1 .182.0.msi
2. C:\AdvanceBox Turbo Flasher\Driver\WinUSB\
3. If still ask drivers, then this path: C:\AdvanceBox Turbo Flasher\Driver\Lumia and Asha Phone Drivers
Page generated in 0.14729 seconds with 9 queries
