Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-27-2014, 07:12   #1 (permalink)
Member: 1536185
Sonork: 100.167.1876
Thanks Meter: 64
nokia c6.01 hang on nokia
i tried to flash with same product code still same and ui settings failed pls help me how to solve.
here is the flashing logs
ATF Software Version v11.30
ATF Box FBUS Flash Started...
Number of Image Files: 5
Forcing Test Mode via BUSCHECK...
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 24B00017
ID DWORD 1 : 27D90344
ID DWORD 2 : FF2F9531
ID DWORD 3 : E4B64690
ID DWORD 4 : 73B2CE05
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum AD
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Boot File - Version 012.014.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 06
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0060 -> Type not in database
Revision ID : 0032
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Checksum : F8
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0060 ExtID :0000 RevID :0032
Flash Descriptor
Device ID : 0060
Revision ID : 0000
Size : 40000000 (1024 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm File - Version 012.014.00
Algorithm File - Revision 0x0003 (3)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02
PHONE FIRMWARE VERSION:
111.040.1511
Scanning Simlock Applet Type...
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum AD
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0032
Block Length : 09
Data : XSR 1.6
Checksum : F8
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0060
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
BB Asic Index : 00
CMT PAPUBKEYS HASH:
111.040.1511
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
OK
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 353759049144383
PRODUCT CODE : 059C1C3
WLAN ID : AC:81:F3:E4:11:5A
BLUETOOTH ID : AC:81:F3:E3:E2:7A
PUBLIC_ID : 24B0001727D90344FF2F9531E4B6469073B2CE05
PAPUB_KEYS_HASH: C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353759049144383\3537590491443 83_113709.rpl
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-718\RM-718_111.040.1511_79u_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 13000000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 565
Entry Point : 0x021F
Page Format : 128K
Maximum Page Size : 0x00040000
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum AD
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0032
Block Length : 09
Data : XSR 1.6
Checksum : F8
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0060
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
BB Asic Index : 00
CMT PAPUBKEYS HASH:
111.040.1511
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00020000
Spare : FFFFFFFF
Num Partitions : 00000005
Partition 1
Attribute : 00000002 RO
Start Address : 00140000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 02B80000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 0DB00000
Partition 4
Start Address : 2E100000
Partition 5
Start Address : 3E600000
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002A40000000000040000000202B800000AF800 0000000008000000010DB00000206000000000002700000001 2E100000105000000000000A000000013E60000000400000F4
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x57 (87)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x23 (35)
Device Index : 0x00
0 : 00040000-0007FFFF
1 : 000C0000-008BFFFF
2 : 00DC0000-0DAFFFFF
3 : 2E100000-3E5FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x03000000
Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:02
Flashing Speed: 5.00 Mhz (AUTO)
Processing : RM-718_111.040.1511_79u_prd.core.fpsx
Total blocks to write : 565
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : SOS+DECOMP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02]
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS+IVE3A
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:01:08
C:\Program Files\Nokia\Phoenix\Products\RM-718\RM-718_111.040.1511_C00.01_79u_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks : 10
Entry Point : 0x0100
Page Format : 128K
Maximum Page Size : 0x00001E00
StartErase_DCT5...
BlockLength : 0x16 (22)
ERASE Blocks : 0x01 (1)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01378000-0139FFFF
1 : 0CC00000-0DAFFFFF
Time Taken to Erase : 00:00:00
Processing : RM-718_111.040.1511_C00.01_79u_prd.rofs3.fpsx
Total blocks to write : 10
>> CMT Rootkey Hash CERT : SOS+ROFS3
>> CMT Rootkey Hash CERT : SOS+IVE3B
Time Taken to Flash : 00:00:00
C:\Program Files\Nokia\Phoenix\Products\RM-718\RM-718_111.040.1511_21.01_India_79u_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks : 141
Entry Point : 0x00F8
Page Format : 128K
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 090C0000-0CBFFFFF
Processing : RM-718_111.040.1511_21.01_India_79u_prd.rofs2.fpsx
Total blocks to write : 141
>> CMT Rootkey Hash CERT : SOS+ROFS2
Time Taken to Flash : 00:00:19
C:\Program Files\Nokia\Phoenix\Products\RM-718\RM-718_111.040.1511_U03.01_79u.uda.fpsx
CMT Type : BB5
Number of Blocks : 852
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 0DB00000-2E0FFFFF
Processing : RM-718_111.040.1511_U03.01_79u.uda.fpsx
Total blocks to write : 852
Time Taken to Flash : 00:02:02
C:\Program Files\Nokia\Phoenix\Products\RM-718\RM601_APE_ONLY_ENO_11w32_v0.064.fpsx
CMT Type : BB5
Program Sending Speed : 6500000 Hz
Number of Blocks : 24
Entry Point : 0x0135
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 008C0000-00DBFFFF
Processing : RM601_APE_ONLY_ENO_11w32_v0.064.fpsx
Total blocks to write : 24
>> CMT Rootkey Hash CERT : SOS*ENO
Time Taken to Flash : 00:00:02
Total Flash Write Time (Flashing Only) : 00:03:32
Total Flashing Time (Booting + Erase + Flashing) : 00:03:37
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Old 05-27-2014, 08:22   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Authorize the phone via ATF Network > Recover Sim Lock Level 2 from phone > Full erase the phone > Flash > See phone power on or not < If not then hardware fault . If yes then Write Recover PM > Restore RPL > SX4 & write PM
Br - srinibas
Old 05-27-2014, 09:19   #3 (permalink)
Member: 1536185
Thanks Meter: 64
thanks for the reply sir but my atf not activated sir any other solution sir may be dead risk sir this process?
Page generated in 0.37459 seconds with 8 queries
