03-09-2017, 16:17 | #47 (permalink) |
Junior Member Join Date: Feb 2012 Location: iran
Member: 1726235 Status: Offline Thanks Meter: 0 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 992EDA82C57744F29B967A1A ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software Helllllppppppppppppp |
03-10-2017, 12:09 | #50 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2683825 Status: Offline Thanks Meter: 6 | hi bro i have problem with rgistration of my atf box for 6 day and now i always saw this error ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 9A91C1FCF2415DAC9BFE9ABC ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ======================= this is my ip : 5.120.41.18 OS : WIN 7 32BIT BROWSER : Chrome |
The Following User Says Thank You to mehdidk For This Useful Post: |
03-11-2017, 03:08 | #53 (permalink) | |
Junior Member Join Date: Jul 2014 Location: indonesia
Member: 2227467 Status: Offline Thanks Meter: 4 | Please Try Again Later (Server Busy) Quote:
================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021224 Library Version : 00030212 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : FA5D7FE2C5AE674 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done | |
03-11-2017, 11:46 | #54 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @All If still error on Activating ATF Box: - Use Full Installer ATF Setup 12.60 (NOT USE 12.67 for Activation; can update after box is Activated). - Add AdvanceBox.exe into your Antivirus exception list... - Add AdvanceBox.exe into your Windows firewall exception list... BR |
03-11-2017, 12:36 | #55 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Moskow
Member: 2691652 Status: Offline Thanks Meter: 60 | I'm sorry but I have not worked. ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030212 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : E56982019190839821389979 ========================================= Please Try Again Later (Server Busy) ========================================= Help. |
03-11-2017, 15:13 | #58 (permalink) | |
Junior Member Join Date: Jan 2009
Member: 955969 Status: Offline Thanks Meter: 1 | Quote:
Server is working now for ATF Nitro/Lightning/Big/Gold. Sorry for the inconvenience. B.R. | |
