11-26-2014, 06:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 37
Member: 199814 Status: Offline Thanks Meter: 1,960 | Init : Failed , check your box firmware ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ please help me to recover this box. it seems kind of semi dead. how to resolve this problem? |
11-26-2014, 09:18 | #2 (permalink) |
Junior Member Join Date: Jul 2012 Location: Czech
Member: 1782977 Status: Offline Thanks Meter: 3 | Sometimes it happend to me too. I just rejoin box to USB or another USB (I am using windows XP, and there is problem) If pop-up message (in system tray), device can run faster if I plug in USB 2. I get your log. If not pop-up. Its ok. I never reinstall, or recover box. Try this. And sorry for my englih I hope it will be helpfull to you. |
