N7100 Block Write CRC Error 0x02 scan ok when i try to remove PERM_WRITE_PROTECT: YES getting error Block Write CRC Error 0x02 ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF7B21653EF30B5 CSD : D02701320F5903FFF6DBFFFF8E406009 eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.7 Product SN : B21653EF Manufactured : March 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF7B21653EF30B5.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung Remove Write Protection ================================================== ==== --> DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC --> Make Sure you BACKUP eMMC DUMP Just In Case... ================================================== ==== Block Write CRC Error 0x02 ERROR: SET_BLOCK_LEN (CMD16) A3 Check your Test Point Soldering! |
Only remove wp for emmc chip samsung brand. Maybe help you http://forum.gsmhosting.com/vbb/f609...tures-1945278/ |
i think your phone stuck on startup logo,,,,and cant flashed with odin in this case firmware of emmc is bad so u cant remove write protection when firmware is bad update firmware+formate will solve your problem1000% |
thanks 4 relpy yes stuck on startup i cant flash with odin tell me how update firmware + formate |
ok with connect data, vcc, vcq, cmd clk 1.8v, 3.3v with tp point |
http://forum.gsmhosting.com/vbb/f609...tures-1945278/ butt files are diferrent for note2 plese search in forume feel free to contact me if u need more help |
