N82-1 rm-313 white screen after flashing !! Nokia N82-1 rm-313 after a successful flash it did not boot and stuck on a black screen, so what I did was:
please help this is my scan: Code: ================================================ |
If there is no LOCAL MODE or TEST MODE display on screen, when you working on it, or when the phone is attached on box, then, try to change display to see if your N82 lcd display is ok. I would do the same thing first |
@ojail bro ur set is ok with software. but try to flash with downgrade version. erase ur set and flash with 31.0.16 version and then restore the rpl and pm. and repair the s.d and check ur set. f still same problem then its will be the hardware problem. bro :) |
and the screen was OK before the first flash |
Brother post here the flash log and the screenshot of your ATF soft we should know that which file you flashed with. |
