07-22-2013, 12:18 | #1 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1983847 Status: Offline Thanks Meter: 0 | Sl3 bruteforce file nokia 6303 failed ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2343300000000000 NETWORK NAME : Orange UK;UK [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed |
07-22-2013, 12:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, it could be your cable problem if this phone is 6303ci RM-638 because I think you will be using Nokia 6303c RM-443 cable. Which doesn't work on 6303ci. But if this phone is 6303c RM-443 then its again your cable problem and this phone cannot create hash on USB cable. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
