N9-00 Restart Problem Done via Flashing just wanted to share this mates
NOKIA N9-00 restart problem http://i301.photobucket.com/albums/n...ps8958413a.jpg
procedure
1) open ( Advance Turbo Flasher )
2) select ( N9-00 : RM-696 )
3) check ( USB Mode )
4) load ( FIRMWARE )
5) tick ( FLASH ) http://i301.photobucket.com/albums/n...ps22318e41.jpg Quote:
Number of Image Files: 1
Processing Image File :
DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin
CMT Type : MAEMO/MEEGO
C:\AdvanceBox Turbo Flasher\Logs\flasher.exe
-F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin
D:\NOKIA\Phoenix\Products\RM-696\
BB5 MEEGO / HARMATTAN FLASHER
1. Turn OFF Phone and wait 10 Seconds...
2. Connect the USB Cable to the PHONE Micro USB Port
3. Connect the USB Cable to the PC USB Port
TIPS & INFORMATION:
1. To Turn OFF the Phone, PRESS and HOLD the POWER
button for at least 10 Seconds...
2. Battery Charging will still work on "DEAD" Phones.
3. Factory Reset will make Flashing 15 minutes longer
and it will Totally Erase the User Data and Remove
the Phone Lock + Security Code as well...
4. Skip ADL Chk will Cold Flash the Device.
Waiting For Phone on USB PORT/s...
REQUIRED MODE: BOOTROM MODE
Sending PRIMARY-BOOT: SUCCESSFUL!
Sending SECONDARY-BOOT: SUCCESSFUL!
SECURE USER DATA ERASING IN PROGRESS
Secure Data Erasing takes about 15 MINUTES...
DO NOT DISCONNECT THE PHONE!!! JUST WAIT...
Estimated time to Finish Erasing: 18:21:39 (24-h Time Format)
Battery Voltage Test: PASSED
Ready to Flash Images to Device...
Processing Image: cert-sw
Processing Image: cmt-2nd
Processing Image: cmt-algo
Processing Image: cmt-mcusw
Processing Image: xloader
Processing Image: secondary
Processing Image: kernel
Processing Image: rootfs
All Images were Succssfully Uploaded!
Software Update Done
[]: Found 1 active devices.
[Nokia N900 USB Phonet]: Opening Connection
[Nokia N900 USB Phonet]: Port opened OK!
Rebooting Phone...
Total Flashing Time (Erase + Flashing) : 00:20:09
(Booting time is NOT Included)
Phone is not Connected OR it is not in the
Required Mode...
Reboot the Phone and Enable "PC Suite" Mode
Life timer data is not yet used...
Life timer: ----:--
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Scanning USB Ports...
Basic Phone Information
MCU Version: V 92_11w51_3 19-04-12 RM-696 (c) Nokia
IMEI Plain : 357923041XXXXX5
IMEI Spare : A357923041XXXXX0
IMEI SV : 3357923041XXXXX40F
Phone Model: Nokia NoRM6
Category : Nokia Reference Mobile
Phone Type : RM-696
Extended Phone Information
Product Serial Number: CCM978385
Product Code : 059J217
Module Code : 0204965
Basic Production Code: 059G8V7
BT MCM Version : 6.15
MCU SW Version : V 92_11w51_3 19-04-12 RM-696 (c) Nokia
HW Version : 1603
RFIC Version : |Alli_4.b.1
DSP Version : 92_11w51_3
LCD Version : fe.91.96
Camera : 0b:0125:02
APE BT Version : 00060000060d0020
Content Pack Version : DFL61_HARMATTAN_10.2011.31-3.MEA
AHNE Version : 21
Bootcode Version : 2.3.6
APE SW Core Version : 40.2012.21.3 V 1.3.2 RM-696 (c) NOKIA.
APE Test Version : V 1.3.2
RETU Version : 11
TAHVO Version : 00
APE HW Version : 1603
Wireless LAN ID : 04:A8:2A:20:3A:27
Bluetooth ID : 04:A8:2A:1F:01:A7
Simlock Information
CONFIG KEY : 0000000000000003
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
DCC ID : NOT USED
Selected VPL File:
RM696_059J217_40.2012.21.3_001.vpl
Variant Details : RM-696 NDT MEA1 MEA2 BLACK 16GB
Software Version : 40.2012.21.3
Product Type : RM-696
Variant Version : 001
| thanks for viewing :D |
