06-21-2012, 19:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | N9 downgrade not allowed - ultimate guide inside !!! Ok seems I need to make it clear to everyone that: 1. ALL N9 CANNOT BE DOWNGRADED TO A LOWER FIRMWARE VERSION and most importantly 2. FIRMWARE VERSION checking WILL INCLUDE THE VARIANT VERSION!!! For example, you got an N9 with the Latest Firmware Version and it came from China with a CHINESE VARIANT Firmware Inside. Typically, CHINESE VARIANT is 003... Sample Filename for Chinese Variant Firmware: DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_003-OEM1-958_ARM.bin Ok, so from the FILENAME, it clearly tells you the following: Firmware Version: 30.2012.07-1 Firmware Variant: 003 So what if you want to flash ARABIC to it??? Will you be able to Flash??? The Answer is YES, IF YOU CAN FIND AN ARABIC VARIANT which is HIGHER than 003... Here are sample filenames for LATEST FIRMWARE with ARABIC: DFL61_HARMATTAN_30.2012.07-1.468.2_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin DFL61_HARMATTAN_30.2012.07-1.334.1_PR_LEGACY_334_ARM_RM-696_PRD_signed.bin Your Phone will accept the ARABIC Firmware for sure, because 468 is BIGGER than 003 and 334 is also BIGGER than 003 So now after flashing with ARABIC, Do you think it is still possible to flash your phone BACK to CHINESE 003 ??? Simple Answer: NO! Why Sir Why ???? Because Arabic Variant 468 or 334 is HIGHER than Chinese Variant 003 !!! DOWNGRADE NOT ALLOWED NOT ALLOWED SIR... So you 2 options if you want to flash back to Chinese... 1. Find a FIRMWARE VARIANT with CHINESE which is BIGGER than 468 (maybe it does not exists)! 2. Wait for a newer FIRMWARE VERSION, higher than 30.2012.07-1 So the next time you guys get an error in ATF Software telling you: ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Please Do not blame the ATF Software, because it is only telling the TRUTH! Find yourself the solution by looking for a flash file with a HIGHER VARIANT and with the correct Language Pack Inisde (if Possible)... Here is an example of a VARIANT with a HIGH NUMBER Australian: DFL61_HARMATTAN_30.2012.07-1.523.2_PR_LEGACY_523_ARM_RM-696_PRD_signed.bin Here is an example of a Variant with a LOW NUMBER DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin I HOPE EVERYTHING IS VERY CLEAR NOW!!! Just search for VARIANTS with HIGH NUMBERS in NAVIFIRM+ Download Latest Version of NaviFirm+ here: http://www.symbian-toys.com/navifirm.aspx B.R. X-Shadow |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
06-23-2012, 15:13 | #3 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,119 | Quote:
I would suggest downloading another flash file with product code 059L800. The filename for version 20.2011.40-4 is: DFL61_HARMATTAN_20.2011.40-4.342.01.1_PR_LEGACY_342_ARM_RM-696_PRD_signed.bin The filename for version 30.2012.07-1 is: DFL61_HARMATTAN_30.2012.07-1.342.01.1_PR_LEGACY_342_ARM_RM-696_PRD_signed.bin The Variant Version is higher than your current 341 and it is also for a Polish Provider (albeit a different one). | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-31-2014, 18:08 | #4 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2320352 Status: Offline Thanks Meter: 0 | My nokia n9 wont start hello, after trying install dual boot in order to instal android something went wrong so i gave up. Now i instal with flashing precedure the latest rom as folows.. Found device RM-696, hardware revision 1602 NOLO version 2.3.6 Version of 'sw-release': DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_480 Success C:\Program Files\Nokia\Flasher>flasher --disable-rd-mode flasher 3.12.1 (Oct 6 2011) Harmattan WARNING: This tool is intended for professional use only. Using it may result in permanently damaging your device or losing the warranty. Suitable USB interface (bootloader/phonet) not found, waiting... Found device RM-696, hardware revision 1602 NOLO version 2.3.6 Version of 'sw-release': DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_480 The device is now in production mode what i need to do as i cant reset hardaware with phoenix software downgrade not alowed. what else i need to do?? thanks |
12-31-2014, 19:51 | #5 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1863004 Status: Offline Thanks Meter: 11 | What happens if you put your N9 in R & D mode and see if Lumia Software Recovery Tool will restore device from here: http://download-fds.webapps.microsof...lInstaller.exe Don't be put off by change of name as still compatible with N9. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
