N9 flashing problem Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending PRIMARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending SECONDARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel after this step init cmt-algo step stuck and error falshing and stop flashing now phones stuck and restart and no imei now is any help for this problem???? |
i was try with other tools also all r stop at cmt stage phone dont have imei now is it will be ok this problem after rpl write?? because ill buy rpl but if its not fix this problem ill loose rpl money so ineed experts help....... |
