Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 10-22-2015, 15:34   #1 (permalink)
RIJAS2010's Avatar
Member: 1417101
Sonork: 100.1619006
Thanks Meter: 157
Question Lumia 1320 rm-994 error flashing
Windows Phone 8/8.1/10 Flashing Started
Loading Flash Files Please Wait...
[DEAD BOOT REPAIR via USB is SUPPORTED]
Windows Phone 8/8.1/10 Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Connect Phone to the USB Port
2. Press and Hold the VOLUME DOWN and POWER Buttons
3. Wait until the Phone Vibrates Shortly...
4. Stop Pressing the Buttons...
If the Phone is DEAD BOOT
2. Install Correct Drivers:
"Nokia Emergency Connectivity" Located at:
C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\
Nokia Phone Info Mode Initiated...
Please wait upto 15 Seconds for SW Reset
1. Press and Hold the VOLUME DOWN and POWER
2. Wait until the Phone Reboots...
3. Wait until you see BIG "NOKIA" Logo
IMEI: 359179050340917
Version: 1.1.1.3
Product Code: 059V6P2
Module Code: 0205881
Continuing Previous Boot...
Please wait upto 30 Seconds for Boot Re-entry
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E90000
Block ID 0x05 : Nokia.MSM8930.P6145.2.0
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100130000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode :
Query Flash App Information...
Flash App Information: 02010F011C00
UEFI App: FLASH APP
Flash App Protocol Version: 1.15
Flash App Implementation Version: 1.28
Query ROOT KEY HASH...
ROOT_KEY_HASH: 64356634FCA08BC9E0D02C14BDB230B0076D31099C9779483D 27F9938EDB99C9
Query PUBLIC ID...
PUBLIC_ID: 93151A1A96364E4D6920F407470CE9922D61E254
Query eMMC Info...
EMMC Manufacture ID: SAMSUNG
EMMC Product SN : D0BFBC5A
EMMC_SIZE: 8 Gigabytes
Query Battery Charge Status...
CHARGING_STATUS: Cannot Read in Flash Mode
Sending Image Signatures...
ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000)
This Flash File is NOT COMPATIBLE with this Phone.
ERROR: Flashing Failed!
PROBLEM
UNABLE TO FIND A BOOTABLE OPTION
BUT I TRIED 3 DIFFRENT FILES THAT FILES ALSO SHOWING THE SAME ISSUE ,
ANY SOLUTION FOR THIS ? , I GOT MANY LUMIA 520 THE SAME PROBLEM ALL DONE WITH NORMAL FLASHING VIA ATF ,
PLS GIVE ME A GOOD SOLUTION
MY ATF JTAG IS NOT ACTIVATED
Old 10-29-2015, 20:07   #2 (permalink)
Member: 244159
Thanks Meter: 16
Having same problem can you help us atf team?
Old 10-29-2015, 20:07   #3 (permalink)
Member: 244159
Thanks Meter: 16
1. Disconnect USB Cable
2. Disconnect Battery
3. Connect Battery
4. Try Again...
Process Cancelled...
Recovery Handle Found! - (WinUSB)
Sending Factory Loader...
Loader Upload Done!
Executing Loader...
Start Loader Done!
Waiting for USB Cycle...
USB Cycle OK!
Device Factory Mode OK!
USB Reconfiguration Done...
eMMC Detected OK...
Extracting Partitions from FFU...
Looking for SBL1...
SBL1 OK
Looking for SBL2...
SBL2 OK
Looking for SBL3...
SBL3 OK
Looking for UEFI...
UEFI OK
Looking for RPM...
RPM OK
Looking for TZ...
TZ OK
Looking for WINSECAPP...
WINSECAPP OK
Extracting Partitions Done!
Start Writing eMMC Blocks at : 0x00000000
Start Writing eMMC Blocks at : 0x01000000
ERROR: eMMC WRITE Failed at 0x01000000
Skipping This Partition...
Start Writing eMMC Blocks at : 0x01200000
ERROR: eMMC WRITE Failed at 0x01200000
7E0D07000000577269746520756E7375636365737366756CF0 5B7E
Old 12-01-2015, 21:53   #4 (permalink)
Pratheesh T K's Avatar
Member: 866865
Sonork: 1645198
Thanks Meter: 182
We can never solve this error by flashing
It is emmc problem
Remove write protection via atf plus
You need to connect via emmc test points and remove the write protection
Old 12-01-2015, 21:54   #5 (permalink)
Member: 866865
Sonork: 1645198
Thanks Meter: 182
It is emmc problem
The Following User Says Thank You to Pratheesh T K For This Useful Post:
Old 12-06-2015, 00:44   #6 (permalink)
Member: 244159
Thanks Meter: 16
How can i do this? please guide me atf team i have faith in your team.
Old 09-27-2016, 06:47   #7 (permalink)
Member: 2629692
Hello all.
My phone is Nokia 1320 Lumia. I have tried to flash it which I have done it before successfully but the flashing was terminated with fail message.
Can anybody help me?
Page generated in 0.25990 seconds with 8 queries
