12-01-2013, 13:50 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @jointaccess ATF JTAG can fix this. It is not related to hardware fault. It is just software fault. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-02-2013, 18:21 | #6 (permalink) |
Insane Poster Join Date: Sep 2013
Member: 2026244 Status: Offline Thanks Meter: 15 | well buddy you haven't follow my posts. JTAG activated, repair boot on Lumia900 is only for reading codes. Waiting some files from x-shadow to solve the problem of "rethink possible" as he stated that it is a software problem and not a hardware one. |
12-02-2013, 19:28 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @skynetto Here is the problem... 1. ATF WILL NEVER RELEASE ANY IMEI MODIFICATION PROCEDURES BECAUSE THIS IS 100% ILLEGAL IN ALL COUNTRIES AND WE CAN GO TO JAIL BECAUSE OF THIS. 2. "Rethink Possible" can be solved 100% via JTAG using same JTAG PINOUT as what we are currently using to read Lumia 900 Unlock Codes. However, I need to check first that your IMEI is 100% working, because this problem is caused by a corrupted EFS2. I do this manually if I have time, via teamviewer... I will not release solution to PUBLIC because of what I write in #1. So if you have this problem, you can message me in Sonork and I will setup a meeting to fix your phone... Of course I will only fix your phone if your IMEI is 100% correct, so you need to know in advance what your IMEI is. If you don't know your IMEI, then I cannot help you as well. B.R. |
12-02-2013, 19:51 | #8 (permalink) |
Member: 2026244 Status: Offline Thanks Meter: 15 | I'm not talking about imei modification here, i'm talking about "rethink possible" problem. This is the problem I had for two months from now and it is a clean IMEI. Here it is so you can check: Code: 359746040989217 That was another problem and I'm not bothering you for that, but I'm bothering you for the first phone and was this phone who convinced me to buy ATF Nitro and so it convinced me buying the JTAG activation finding that all my time and money was wasted for nothing because ufficially ATF supports firmware loading, and unlock code reading. IT IS A HUGE HELP I'm not blaming for this but for me it doesn't help me at all because I'm stucked at "rethink possible". Hope you get the picture after all this. Thanks and best regards skynetto p.s.: I've sended you twice the S/N of my Nitro box in PM and in public forum but as I said to Angel it was a dead end. ps2: All the info I've for this phone is here Code: SKU: 65475 Code: 059M7R4: 280312 IMEI: 359746040989217 Type: RM-808 |
12-02-2013, 20:09 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @skynetto Solution to fix this phone "touches" imei... that is why it will never be public. Now I remember your PM and my promise to you. Too many messages in PM... Check PM within 20 minutes. |
12-02-2013, 20:16 | #12 (permalink) |
Member: 2026244 Status: Offline Thanks Meter: 15 | OK thanks. Again sorry to bother you but I've a brick in my desk for two months by now Code: Software Version : v10.41 AdvanceBox SN : 81D3888A807B4AFE9D033B77 Box Status : ACTIVATED |
12-02-2013, 20:28 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @skynetto Wire up phone same as when you unlock Lumia 900... 25 MB File currently uploading. Link will appear in your PM after it finishes. File is locked to your ATF BOX SN. B.R. |
