Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-10-2012, 08:21   #1 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
Need help nokia E6 Rm-609 Downgrade <<< Answered >>>
hi i need help to downgrade e6 AFTER downgrade i write rpl back,
and when i whant Athorize BB5 in ATF network i see this error
SearchForBootstrap_DCT5..
ERROR: SECONDARY LOADER NOT FOUND
ERROR: Sending Loader Failed...
what this ????
Old 07-10-2012, 08:35   #2 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
Sory Problem Soloved
AFter Update important files
Thanks!1
Old 07-10-2012, 09:27   #3 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
ooo other problem
when im flash old firmware phone power on without imei when im write rpl, after rpl phone not power on, ?????????
only nokia logo and restart
why?
Old 07-10-2012, 09:38   #4 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
Originally Posted by SEMEN View Post
ooo other problem
why?
bro write the pm file and repair the S.D......
then check ur set.... f same problem then post here the logs....
bro
Old 07-10-2012, 09:43   #5 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
ooo other problem
why?
dont write full rpl. u need some skill for downgrade sl3
B,R-chami_dongle
Old 07-10-2012, 09:47   #6 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
B,R-chami_dongle
oooo you sirios, if you don`t know what you say beter don`t say nothing,
about wich skill you say?
Old 07-10-2012, 09:49   #7 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
bro
i can`t repear sd phone most power on, and my phone nokia logo only
Old 07-10-2012, 10:44   #8 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
@ SEMEN
Just follow this procedure
1. Backup RPL - IMEI and LOCKS->IMEI->Backup RPL
2. Backup Full PM - PM/PP->Read Full PM
3. Full Erase Phone - Flashing->EraseFlash->Scan->Erase
4. Write Flash with lower version - Flashing->WriteFlash - ENO needed for supported models
5. Write Backup RPL - IMEI and LOCKS->IMEI->Write RPL
6. Authorize Phone - ATF Network->Login to account-> Authorize a BB5 NEW HASH Phone
7. Repair SD and Writing PM Backup - PM/PP->Stand Alone SX4->SX4 PM Authorization->Select PM Backup
Post result
Br - srinibas
Old 07-10-2012, 11:07   #9 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
bro download the eno file from NAVIFIRM+...
u will be find the eno file in 111.130.625 r 111.130.622 version...
erase ur set write the eno flash with any version write rpl file and then write pm file
and then try to repair....
bro
Old 07-10-2012, 11:38   #10 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
Originally Posted by srinibas View Post
@ SEMEN
Post result
Br - srinibas
i after step 6 my phone only nokia and black scren,
and i can`t repear sd, becose my phonnot power on,
Old 07-10-2012, 11:46   #11 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
bro
i use eno files APEONLY eno fpsx
Old 07-10-2012, 12:16   #12 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
Full Erase
Booting Phone via USB...
USB Phone BUSCheck Boot
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeded After 0 Tries
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 25000206
ID DWORD 1 : 44D90344
ID DWORD 2 : 0922EC48
ID DWORD 3 : 4ED242E5
ID DWORD 4 : 70A27C8C
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0068 -> Type not in database
Revision ID : 0031
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0031
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0068
Revision ID : 0000
Size : 40000000 (1024 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
327C6B67C95DA04A763DEFD4BA15C19FF16D9AE7
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x0B (11)
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
0 : 00000000-3FFFFFFF
ERASE_REQUEST_BB5 : 5001120B000300000000003FFFFFFFA2
Successfully Erased...
FlashInfo.RestartMode : Test Mode
Process Done...
Im Flash Eno Files
Number of Image Files: 1
Processing Image File :
RM-609_APEONLY_eno.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 24
Entry Point: 0x0138
Page Format : -1
MAX PAGE : 0x00040000
AUTO SELECTED DEAD USB FLASHING...
2. Insert USB.
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
MessageID : C1
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data :
Flash Descriptor
Device ID : 0068
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
FUR control Ok
Pabub KEY Request
No PAPUBKeysHash Returned
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-609\
ImageFilename: RM-609_APEONLY_eno.fpsx
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
Device Index : 0x00
0 : 008C0000-00DBFFFF
ERASE_REQUEST_BB5 : 5001120B000300008C000000DBFFFF79
Total blocks to write : 24
>> CMT Rootkey Hash CERT : SOS*ENO
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000005
Additional Bad : 00000005
Correctable ECC : 00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:00
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
full flash with lower version
Number of Image Files: 3
RM-609_021.014_79.92_prd.core.fpsx
CMT Type : BB5
Program Sending Speed : 13000000Hz
Number of Blocks : 508
Entry Point: 0x0214
Page Format : -1
RM-609_021.014_00.01_79.92_prd.rofs3.fpsx
CMT Type : BB5
Entry Point: 0x00EE
Page Format : -1
MAX PAGE : 0x00003800
RM-609_021.014_24.01_Hebrew_QW_79.92_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks : 163
Entry Point: 0x00F4
Page Format : -1
2. Insert USB.
BootFlashMode_DCT5
READING BOOTROM
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
MessageID : C1
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data :
Flash Descriptor
Device ID : 0068
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
FUR control Ok
Pabub KEY Request
ImageFilename: RM-609_021.014_79.92_prd.core.fpsx
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
ProcessPartitionInfo_DCT5...
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002F200000000000400000002030600000E6A00 000000000800000001117000001CA000000000002700000001 2E100000105000000000000A000000013E60000000400000E1
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x57 (87)
ERASE Blocks : 0x02 (2)
Block Length : 0x23 (35)
Device Index : 0x00
0 : 00040000-0007FFFF
1 : 000C0000-008BFFFF
2 : 010C0000-116FFFFF
3 : 2E100000-3E5FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x03000000
Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5004120B000300000400000007FFFF120B000300000C000000 8BFFFF120B000300010C0000116FFFFF120B0003002E100000 3E5FFFFF79
FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025
Total blocks to write : 508
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-609_021.014_00.01_79.92_prd.rofs3.fpsx
StartErase_DCT5...
Device Index : 0x00
0 : 10380000-116FFFFF
ERASE_REQUEST_BB5 : 5001120B00030010380000116FFFFF18
>> CMT Rootkey Hash CERT : SOS+ROFS3
ImageFilename: RM-609_021.014_24.01_Hebrew_QW_79.92_prd.rofs2.fpsx
StartErase_DCT5...
Device Index : 0x00
0 : 0C000000-1037FFFF
ERASE_REQUEST_BB5 : 5001120B0003000C0000001037FFFF8D
Total blocks to write : 163
>> CMT Rootkey Hash CERT : SOS+ROFS2
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:22
Phone not power on becose i flash eno files without flash eno files phone power on with imei 123456789, but after rpl only nokia logo and black skren
Old 07-10-2012, 14:54   #13 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
@SEMEN
bro add me n sonork i will check via teamviewer.............
bro
Old 07-10-2012, 16:49   #14 (permalink)
Member: 1133072
Thanks Meter: 505
double check ur said word is correct or incorrect?
it can authorized to severer.. meaning is ur phone can get test mode.
can get phone to test mode surely can repair SD
B,R-chami_dongle
Old 07-10-2012, 16:58   #15 (permalink)
Member: 1133072
Thanks Meter: 505
i not say any wrong thing,
just i say about phone repairing skill (need some skill for repair mobile phones)
anywhare i not say , "u not have skill"
dont be worry. u have good skill..,, bla,. bla.. blaa.....
B,R-chami_dongle
Page generated in 0.30411 seconds with 8 queries
