Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-25-2013, 13:52   #1 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
ATF First In The World Nokia 301/3018 (XG618) Full Flashing
ATF First In The World Nokia 301/3010 Full Flashing !!!!
ATF always First, No Matter its new model or not, ATF Ready To do , get ATF work should b more easier !!
its Beta Version should release full version as soon as possible!
Here is Screen Shot ,
Here is Flashing Log:
Number of Image Files: 3
Processing Image File :
 rm840__02.03b.mcusw
 rm840__02.03b.ppm_e3
 rm840__02.03b.image_e3_059R1S2
[]: Found 1 active devices.
[Nokia USB Phonet]: Opening Connection
[Nokia USB Phonet]: Port opened OK!
SW: V 02.03b 08-04-13 RM-840 (c) Nokia
IMEI: 355520050408630
 START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
 FULL PM Backup Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355520050408630\USB_FULL_BACKUP_V 02.03b 08-04-13 RM-840 (c) Nokia_355520050408630__042301.pm
Reading Battery Value  : 3728 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB Cable and Battery...
2. Connect USB Cable.
3. Connect Battery.
***** IF PHONE STARTS CHARGING OR DOES NOT BOOT *****
******* REMOVE BATTERY AND PUT IT BACK AGAIN. *******
Infineon Boot: F01650A9070100030101A0400809000C8DE4493A90B4FFFF
         <<<< Connect Battery Now >>>>
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Boot Successful...
Unique Data: A0400809000C8DE4-493A90B4
Original Product Code: 059R1S2
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355520050408630\355520050408630_042309.rpl
Current File    : rm840__02.03b.mcusw
Number of Images: 8
psi_flash_unsigned.fls
slb_signed.fls
main_toc_signed.fls
rm840__02.03b.mcusw_signed_mcusw.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
Processing Data Block 0x00
Erase Block: 0x00090000~0x000A0FDE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Start Writing...
Finalizing...
Data Block Write Done...
Processing Data Block 0x01
Erase Block: 0x60000000~0x6003FFFE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x02
Erase Block: 0x60040000~0x600403FE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x03
Erase Block: 0x62E00000~0x63D03DCA
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Erase Block: 0xFFF00000~0xFFF7FFFE
Start Erasing...
Block Erase Done...
Processing Data Block 0x04
Erase Block: 0x80000000~0x80C13E9A
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x05
Erase Block: 0x62080000~0x620C3FFE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x06
Erase Block: 0x63F79C00~0x63FF046E
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x07
Erase Block: 0x61F00004~0x62045396
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Current File    : rm840__02.03b.ppm_e3
Number of Images: 1
package_e3.ppm_ebl_psi.fls
Erase Block: 0x80F00000~0x816340E2
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Current File    : rm840__02.03b.image_e3_059R1S2
Number of Images: 1
package_e3_059R1S2.image.fls
Erase Block: 0xA1000000~0xA27597FE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Erase Block: 0xAE000000~0xAE2FFFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:00:13
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 02.03b 08-04-13 RM-840 (c) Nokia
IMEI Plain : 355520050408630
IMEI Spare : A355520050408630
IMEI SV    : 33555200504086304F
Phone Model: Nokia 301
Category   : Phone
Phone Type : RM-840
            Extended Phone Information
Product Serial Number: FECC7F5AH
Product Code         : 059R1S2
Module Code          : 0205267
Basic Production Code: 059P5R1
Long Production SN   : 0
PPM SW Version       : V 02.03b 08-04-13 RM-840 (c) Nokia            E3
ADSP Version         : PMU_MAXIM8939B
MCU SW Version       : V 02.03b 08-04-13 RM-840 (c) Nokia
HW Version           : 1000
UPP Version          : MFR:0x20,DEV:0x40,REV:0x131
RFIC Version         : 152
LCD Version          : TPO
Content Pack Version : Content: e3_059R1S2 V 02.03b 08-04-13 RM-840 (c) Nokia
AHNE Version         : 13
RETU Version         : PMU_MAXIM8939B
Bluetooth ID         : BC:C6:DB:F3:1A:3D
CS Type              : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC         : 11
PROVIDER     : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3,  FBUS 0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE             : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 01035602
DCC Ver: 006004
Status   : OK
Selected VPL File:
RM840_059R1J0_02.03b_031.vpl
Variant Details     : RM-840 MEA_M3_CYAN_ARABIC_JO
Software Version : 02.03b
Product Type       : RM-840
Product Code      : 059R1J0
Variant Version    : 031
Selected VPL File:
RM840_059R1S2_02.03b_030.vpl
Variant Details     : RM-840 EURO_E3_WHITE_LATIN_RO
Variant Version    : 030
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Life timer data is not yet used...
Life timer: ----:--
Here is the device with my ATF !!!
Thanks ATF Team,
its beta version so wait for till official release will announce here......
WAJID
The Following 14 Users Say Thank You to WAJID PNR For This Useful Post:
Old 05-26-2013, 06:46   #2 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
Thnx 4 test report. upload flash file plz .mediafire.com
Old 05-26-2013, 06:54   #3 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 248
good information brother...............
Old 05-26-2013, 07:07   #4 (permalink)
Member: 1652269
Sonork: 100.1638989
Thanks Meter: 54
Good information brother...............
Old 05-26-2013, 07:07   #5 (permalink)
SOFTWARE.HELP's Avatar
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 337
always first to introduce us new models..... thats ATF
Old 05-26-2013, 11:40   #6 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
here is arabic firmware :
RM-840 - Download - 4shared
The Following User Says Thank You to WAJID PNR For This Useful Post:
Old 05-26-2013, 12:24   #7 (permalink)
Member: 1908388
Thanks Meter: 24
Hello sir wajid pnr advance box samsung software realse yes or no....
Old 05-26-2013, 12:25   #8 (permalink)
Member: 1908388
Thanks Meter: 24
Please tell me...... About samsung software
Old 05-26-2013, 12:25   #9 (permalink)
Member: 1908388
Thanks Meter: 24
I am waiting..........,,,,,,,
Old 05-26-2013, 13:29   #10 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
http://forum.gsmhosting.com/vbb/f609...ml#post9403152
Old 05-28-2013, 04:22   #11 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
Originally Posted by WAJID PNR View Post
ok great man tks! now pld rollout the new version! waiting for it!
WBR
ReyTech.
Old 05-28-2013, 20:30   #12 (permalink)
Member: 711832
Thanks Meter: 2
need v9.90 beta verstion plz
 rm840__02.03b.mcusw
Please Wait...
Rebooting Phone...
3. Connect Battery.
Sending PBL...
Sending SBL...
 Plain RPL saved to:
Number of Images: 8
slb_signed.fls
main_toc_signed.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Number of Images: 1
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Number of Images: 1
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Category   : Phone
Phone Type : RM-840
HW Version           : 1000
RFIC Version         : 152
LCD Version          : TPO
AHNE Version         : 13
ASIC         : 11
PHONE_MODE              : TEST
DCC ID  : 01035602
DCC Ver: 006004
Status   : OK
Selected VPL File:
Selected VPL File:
 OK
 OK
 OK
 OK
 OK
 OK
Life timer: ----:--
Thanks ATF Team,
WAJID
plz i want this atf v9.90 beta verstion plz.so share me any link to download it plzplzplz
The Following User Says Thank You to rito_softboy For This Useful Post:
Old 05-29-2013, 16:01   #13 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Officially released ATF 9.90:
http://forum.gsmhosting.com/vbb/9461672-post1.html
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 07-23-2014, 19:26   #14 (permalink)
Member: 2212971
Hello
I try to unlock Nokia 301 RM-840 with ATF, but is not work...i dont have any connection to phone. Please help...
Thanks
Old 07-24-2014, 10:14   #15 (permalink)
Member: 643472
Sonork: 100.96901
Originally Posted by Hebu1 View Post
Hello
Thanks
Post here software logs.
Page generated in 0.21981 seconds with 8 queries
