09-23-2010, 08:41 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: thailand
Member: 451521 Status: Offline Thanks Meter: 317 | Advance-Box PLZ CHK 5130 USB DEAD i use atf flash nokia 5130 by usb ERROR: ADL Loader was not accepted But can can flash Fbus done ! Log See... Number of Image Files: 3 Processing Image File : rm495__07.96.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm495__07.96.ppm_u CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 476 Entry Point: 0x00BE Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm495__07.96.image_u_blu CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 656 Entry Point: 0x00D0 Page Format : -1 MAX PAGE : 0x00004000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 cmt hardware : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C900217 ID DWORD 1 : 7E028C56 ID DWORD 2 : B80597FC ID DWORD 3 : 525DBD7A ID DWORD 4 : DB2186CE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F START FLASHING RawLoaderExtract: Processing rm495__07.96.mcusw RawLoaderExtract: Image matches with RootKey Hash, Extraction is done Parsed OK RAW LOADER SENT.. UpdateAgentDataExtract: Processing rm495__07.96.mcusw UpdateAgentDataExtract: Found matching Rootkey Hash CERT Block UpdateAgentDataExtract: Found DATA Block UpdateAgentDataExtract: Consolidating DATA Blocks PASUBTOCCertExtract: Processing rm495__07.96.mcusw PASUBTOCCertExtract: Found matching Rootkey Hash CERT Block 00000400 Update Agent Sent.. Waiting for phone to ADL ... (Make take a while) ERROR: ADL Loader was not accepted PAPUB Key HASH is EMPTY or BLANK. This Phone CANNOT be flashed with DEAD USB Use FBUS Flashing to revive this phone... Booting/Flashing Failed... Please Try Again... |
09-23-2010, 10:33 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 417 | go to "Support Tab" then "Box Tools" then click ONLY "Restore Box" and nothing else. Wait maybe for 3 minutes until it finishes, then try to flash again. |
06-07-2014, 09:46 | #4 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1410829 Status: Offline Sonork: Sonork ID Thanks Meter: 0 | my nokia 5130 is dead atf box nitro its stucks at 6% and then not booting up VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed Failed to complete RPL backup.. Processing Image File : D:\New folder (3)\C5F02102_rm495__07.97 (1).mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 1178 Entry Point : 0x5057 Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed Operations Failed.... |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
how to unlock 5130 | accelr8 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-24-2010 17:52 |
5130 5190 6190 | MGG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-03-2000 20:36 |
Plz help with unlock NOKIA 6110 2lock | henr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:29 |
