Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
Here is official Samsung Instructions about TP on this tablet: PVI 13-03A - GT-N8000 Recovery Bootloader (J-Tag) Guide - Download - 4shared - Linus Hernandez Of course you can also write BOOT via eMMC direct connection if TP still not work.. Anyway read PDF and make SDC using ATF plus Image too. Make sure your BOOT version is high version before making SDC. | |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2011 Location: sweden
Member: 1609777 Status: Offline Thanks Meter: 55 | thank you Advance-Box about This information.I had worked update to 4.4.2 later update died n8000. Any file can be i used please? Is it possible to put SDC 4.1.2 And also there is only SDC N8000XXCMA5_4.1.2_32GB and sdc GT-N8000XXCMA5_4.1.2_64GB but my tab is 16 GB .Can help me please what i do please. |
The Following User Says Thank You to nabel_sweed For This Useful Post: |
![]() | #4 (permalink) | |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | Quote:
Sir ,I tried hard but could not boot with sd card,even the tp shortened correctly, Than i connected EMMC testpoint and ,this way i Connected with EMMC successfully. Than i wrote the latest fw 4.4.2 through tp, ------------------------------------------ ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D414732474107BB1FF1482FF7 CSD : D02701320F5903FFF6DBFFFF8A404007 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MAG2GA Product Rev : 0.7 Product SN : BB1FF148 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D414732474107BB1FF1482FF7.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x000006C5 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:04 Write Success! Flash Image: tz.img Start Writing 0x00000138 Blocks at 0x000006C6 Partition Selected: BOOT 1 Total Elapsed Time 00:00:00 Write Success! Flash Image: boot.img Start Writing 0x00002CA5 Blocks at 0x00014000 Partition Selected: USER AREA Total Elapsed Time 00:00:39 Write Success! Flash Image: recovery.img Start Writing 0x000035B5 Blocks at 0x00018000 Partition Selected: USER AREA Total Elapsed Time 00:01:48 Write Success! Warning: EXT3/4 Image Detected Skipping system.img... Flash Image: modem.bin Start Writing 0x00006001 Blocks at 0x0001C000 Partition Selected: USER AREA Total Elapsed Time 00:01:55 Write Success! Warning: EXT3/4 Image Detected Skipping cache.img... Warning: EXT3/4 Image Detected Skipping hidden.img... Total Images Written: 5 Process Done! ------------------------------------------------------ But the tab is still dead. Pl guide me what to do next,Should i do ''normal factory erase'' before write anything and what should exactly be written to the EMMC,to put tab in dnload mode? ---------------------------------------------------- the tab was dead while flashing this fw. N8000XXUDNH2_N8000OJVDNH1_XSG. ![]() | |
![]() | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @khawar Did you remove eMMC Wires before you tried to check if the phone can enter download mode? If wires are still connected, sometimes phone will not power on. Also check battery voltage. N8000XXUDNH2 <--- this is already 4.4.2 .... So not sure why your TAB died when you flashed this version. So what is the filename of the file that you used to write TAR.MD5 via TP? Normal Factory Erase can be used, but make sure to backup first atleast first 512MB of your Phone. (1GB if you have 10 minutes to spare). With phone backup, you can use it to restore IMEI, Simlocks etc.. later when phone is booting. |
![]() | #6 (permalink) |
Member: 51218 Status: Offline Thanks Meter: 77 | sir, when the tab came to my shop it was on 4.0.1, and it died when updated to 4.4.2,update went successfuly completed,but when rebooted it is dead. Battery is 100% confirmed charged. Can i write boot file from older ver like 4.1.2? Also pl guide to backup efs via jtag (which 512 mb )? |
![]() | #7 (permalink) | |
Sorry for the above stupid post, I made backup. the set came with 4.0.4. ![]() NOW Only one help needed please. Pl provide me these three files for n8000. BOOT1 , BOOT2 and USERDATA. when i try to extact from fw file i find boot and sboot, But cant find Boot1 and boot2, ? I hope this ll solve my problem. WR KHAWAR | |
![]() | #8 (permalink) | |
You just need "USER AREA" and "BOOT1"... Here is link for both files with Version 4.0.4 of GT-N8000. GT-N8000_N8000XXALI3.rar <=== Download Also, before writing DUMP above, you must backup USER AREA 512MB as well... Then upload it somewhere for me to download it. We can check whether your phone has older PIT inside which not allow it to work on 4.4.2. Normally, I think need to "Re-Partition" when flashing with ODIN when you come from very OLD firmware verstion. | |
![]() | #9 (permalink) |
Member: 51218 Status: Offline Thanks Meter: 77 | Thank you for the help, Here is the 512mb dump from my tab, http://www.4shared.com/rar/Pu5E_3WUb...0_0x000FF.html please check it and guide me further, I cant understand what is wrong as i ve tried every possible way to get it alive but no success. If the PIT is damadged(which i think is our only hope now),how to re-partition,? Here is what i did today, 1- made backup,which has been uploaded for you to check. 2-did normal factory erase. 3-did Samsung factory format. 4-wrote EXT_ csd backup. 5-wrote user area and boot,provided by you in last post. All steps went successfully,without any error. Than i removed tp and tried to put the tab in dnload mode,with fully charged batt, But still nothing ,still no dnload mode ,nothing, ![]() --------------------------------------- It is 100% confirmed that it died during flashing with odin. and the test points are conected very carefully. Please do something as the customer is now on my head. WR KHAWAR Last edited by khawar; 03-04-2015 at 19:33. |
![]() | #10 (permalink) | |
![]() | #11 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @khawar I already gave you what you asked for, which was a low version 100% working dump. If nothing else, then prepare ammyy and contact me via PM when ready. I will try to erase your eMMC Properly. |
