Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-09-2015, 01:06   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Unhappy nokia lumia 800 flashing error
I can't write firmware on this phone,the problem is that phone was allmost ok before flashing with other tool (it was turning off after some time so I decided to write firmware on it)...now phone is dead,how to repair it????
Windows Phone Flashing Started
OSBL File Found:
RM801_12w22_prod_generic_nokia_osbl.esco
AMSS File Found:
RM801_12w22_prod_generic_amss.esco
ADSP File Found:
RM801_12w22_prod_generic_adsp.esco
WPOS File Found:
RM801_12220_prod_490_01_boot.esco
USER AREA ERASE File Found:
RM801_12w22_prod_generic_user_area_erase.esco
Windows Phone Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 8 more
seconds
ERROR: Data Rejected at SEQ 0x1
ERROR: Data Rejected at SEQ 0x2
Sending OSBL Certificate
HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E
Certificate Size: 452 Bytes
ERROR: Data Rejected at SEQ 0x3
Status : WRITE OSBL CERTIFICATE FAILED
Old 09-10-2015, 21:04   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
You can repair lumia 800 with ATF using Test Point. But if the phone is taking NokiaConnectivityDriver than is not dead boot. Log says, boot is alive. But keystore is damaged. Unfortunately, ATF doesn't support damaged keystore repair for lumia wp7 phones.
Old 09-11-2015, 22:04   #3 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question
Indeed, I have succesfully managed to repair boot via TP but phone still dead...phone was alive before flashing it with Best...there is any tool ,or method that can repair damaged keystore on this phone?
Old 09-11-2015, 22:12   #4 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question
But man,I have found this:http://forum.gsmhosting.com/vbb/f609...epair-1673102/
This coud not help me?
Old 09-16-2015, 16:37   #5 (permalink)
Member: 643472
Sonork: 100.96901
Yeah, this can fix your phone. Sorry, I forgot about this, 710 and 800 can be repaired with this method and for other WP7 need repair keystore.
Page generated in 0.16967 seconds with 8 queries
