08-01-2014, 07:49 | #1 (permalink) |
Junior Member Join Date: Apr 2010 Location: republika ng pilipinas!!!
Member: 1285600 Status: Offline Thanks Meter: 2 | Nokia E63 SimLock status Damaged pls help Nokia E63 SimLock status Damaged pls help log Lock info =========== IMEI : 3533970----- IMEI spNet : 3A 35 93 07 34 80 94 03 IMEI svNet : 33 35 93 07 34 80 94 13 F7 Unable to read Lock table... CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 i try recovery simlock recovery using atf but show this error level 1 ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... REPORT: Simlock Hashes was NOT FOUND! REPORT: Simlock Signature was NOT FOUND! REPORT: Simlock Recovery FAILED! REPORT: Try Level 2 or Level 3 Recovery REPORT: Total Elapsed Time 00:00:22 level 2 ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: PMM Storage Found at 0x0007E000 STATUS: Defragmenting XSR2 Blocks REPORT: XSR2 Fragmentation Level is LOW REPORT: Defragmentation will take a few SECONDS! REPORT: Simlocks Verification FAILED! REPORT: PM 120 Sections Corrupted! Level 2 Recovery CANNOT Continue Level 3 Recovery is NEEDED for this Phone REPORT: Simlock Recovery Profile Saved C:\AdvanceBox Turbo Flasher\Nokia\Backup\353397043084931\3533970430849 31_9B17495CEF6E0BC5A1D6D1EB.srp You can upload this via The ATF Network if You Are Interested to perform Level 3 Recovery... REPORT: Total Elapsed Time 00:11:51 level 3 i dont have credits for level 3 ATF team do you have solution for this error? pls help me |
08-01-2014, 13:03 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @khell_tech Post here BUS CHECK log to see if phone is using NEW or OLD HASH. If using new hash, then only solution is NOKIA RPL BR |
