04-15-2011, 11:15 | #18 (permalink) |
Freak Poster Join Date: Mar 2011 Location: DERGAON
Member: 1536672 Status: Offline Sonork: [email protected] Thanks Meter: 19 | atf solv bro remove atf driver from device maneger and after connect atf box and install atf driver |
04-23-2011, 05:49 | #19 (permalink) |
Freak Poster Join Date: Jul 2001 Location: nil Age: 48
Member: 5291 Status: Offline Sonork: nil Thanks Meter: 7 | Hi after i press reset box now not detect my advance box. I have try unistall and reinstall sw also atf driver from device manager and after connect atf box and install atf driver from ATF_NEW_DRIVERS.. From Remove_ATF_Drivers also try Green light ok,open sw show Turbo nitro.. Can you post the solution |
04-27-2011, 14:14 | #20 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Gautam Buddha Nagar Age: 35
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | |
04-27-2011, 14:18 | #21 (permalink) |
No Life Poster Join Date: May 2007 Location: lahore
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | Some days ago i was also face this kind of problem...U need a good usb extension cable.because atf is so sencitive in this case,check ur box direct in ur p.c usb port,,i m sure ur problem well b save.. |
04-27-2011, 14:20 | #22 (permalink) | |
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | Quote:
atf boxes found-----slect the box serial number that you want to use for this atf software windo---errore plz slect a box fromthe list-----plz help-----i install an other pc but not don Turbo flasher box jo sab se phale aaya tha bo box hai sir ji plz needid help | |
06-18-2011, 14:04 | #24 (permalink) |
Insane Poster Join Date: Nov 2007 Location: india, kakinada
Member: 627678 Status: Offline Thanks Meter: 14 | I have purchased 10 days ago ATF LIGHT Box. Still I didn't use usefully the ATF Box. Allways ATF Box shows "Check Your Box Firmware". I have been trying to solve the problem, as per Form threads information. Now my box serial no. shows "Zeors". But I con't do solve the problem. Please help me to solve the problem. |
12-13-2012, 07:49 | #28 (permalink) |
Junior Member Join Date: Dec 2008 Location: panipat
Member: 931817 Status: Offline Sonork: prashant Thanks Meter: 1 | help i have one atf box which is not detected although driver seems ok. When i open atf, in the nokia service i see TURBO NITRO & after i go Product Support MENU at Box Tools, there i see blank fields needs to be filled. After necessary fillings, when i press ACTIVATE BOX it shows me as "YOUR BOX HAVE NO SERIAL NO" n when i press Restore Box it shows me "NO ADVANCE BOX FOUND"............ i AM CONFUSED n wondering what to do.... please help------i uninstall driver--and change another pc but not solve-- my -box is liting-small---i am ery upset- |
07-16-2013, 17:37 | #29 (permalink) |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | Also same problem I just recived my ATF NITRO and cant activate. Shows you box has no serial number. I have team viewer installed and ready for help please |
