02-08-2015, 14:05 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Loock the release in vers. 11.40: SPI Tool 1.0 Initial Release --> Direct In Circuit Programming for Small SPI Flash ICs --> NO NEED to remove SPI Flash from PCB --> Ideal for Nokia 105 and 106 Direct SPI Flash Programming --> Ideal for HUAWEI WiMax Modem SPI Reprogramming --> Read/Write Speeds upto 30 Mhz --> Supports CPOL=0, CPHA=0 and CPOL=1, CPHA=1 SPI Modes --> Auto Verify and Auto Rewrite Corrupted Sectors --> Selectable VCCIO Voltage (1.80v, 2.80v and 3.30v) --> Selectable Instruction Set according to SPI Flash IC Brand --> Automatically Detects Flash IC Capacity for Micron/Numonyx --> Automatically Skips IMEI, Simlocks and PM Region of Nokia 105 and 106 * When used with Nokia 105 and 106, you can: ----> Read Full Dump from 100% Working Phone and write it to another phone without damaging the IMEI, Simlocks and PM Region. ----> Write MCU+PPM+CNT, or just PPM+CNT or just PPM only ----> Allows Cross Version PPM Files to be written on any MCU Firmware Version ----> Now you can write your prefered BIG Language Packs which was not supported in FBUS ----> You can read FULL DUMP via FBUS and write it to other phones via SPI Tool Here Diagram: BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
