nokia 1616 sucesfully flash using dolphin clip finder help of ATF VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: E:\Nokia Flash File\RH-125\rh125_006.510 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 3199 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2174080 bytes Data Checksum: C7A8 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: E:\Nokia Flash File\RH-125\rh125_006.51ia Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x0040ACFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2075904 bytes Data Checksum: B9E4 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: E:\Nokia Flash File\RH-125\rh1250_nai06.51ia Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F08E7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 364160 bytes Data Checksum: D851 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:52 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.51 13-05-11 RH-125 (c) Nokia IMEI: 353407047935283 Product Serial Number: 1B5FCBAAI Product Code : 0595859 Module Code : 0204343 Basic Production Code: 059C283 PPM SW Version : V 06.51 13-05-11 RH-125 (c) Nokia IA ADSP Version : p V 06.51\n13-05-11\nRH-125\n(c) NMP\nia MCU SW Version : V 06.51 13-05-11 RH-125 (c) Nokia HW Version : 1003 UEM Version : 1328 UPP Version : 8850 LCD Version : INNO:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
