Nokia 521 JTAG PROBLEMS - (PINOUTS INSIDE ALREADY) |
Be kind, give advice on the restoration of this unit. |
@ivan I saw this pic in russian forum. Are you the owner of the phone? If so, I see you tried to remove shield of CPU... Did you try to connect via EMMC TP? Anyway, for JTAG connection, I believe it is under that metal shield which is second From the left side. Almost same location as 520 RM-914. Can you take picture of other side of pcb as well? Maybe emmc connection is easier For this phone. B.R. |
This is a phone I had to decode! I tried to decode it using the function REPAIR BOOT got a corpse. Now he's in the system is determined ... http://s003.radikal.ru/i202/1401/f4/1dca86452564.jpg http://s020.radikal.ru/i718/1401/f1/26ea17bb4c78.jpg This client machine!( p/s Sorry for my english!! I use a translator. |
As I understand, there is no solution? |
Br - srinibas |
Photo from the top.... Here you can put the correct TP!!! |
Does anyone have the right pinout for Nokia 521? |
Br - srinibas |
Just use a knife to cut the glue to remove the heat shield? |
I was wondering that color orange, what does it mean T+S |
S = SYSRST You need to take out 2 cooper wires from ORANGE and connect one to T and second one to S on board. BR |
Thank you so much for the instruction, i have this Atf box a year ago but havent try once, so this is my first time using it, one more thing, i don't cable, so i was wondering to make one, but R45 has only 8 slot, but to the pic I saw 10 so can you give me a proper way how to modified cable... Sent from my SM-G900F using Tapatalk |
