09-21-2012, 07:28 | #1 (permalink) |
Insane Poster Join Date: Jul 2010
Member: 1352686 Status: Offline Thanks Meter: 3 | just bought today the log here ================================================ Advance Turbo Flasher Found ================================================ Driver Version : - Library Version : - Box Type : ATF Nitro Box Firmware : LogiCore 10.3.12 Software Version : v8.70 AdvanceBox SN : - Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ |
09-21-2012, 08:22 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
09-21-2012, 10:12 | #8 (permalink) |
Member: 1352686 Status: Offline Thanks Meter: 3 | okay now i already install nokia pc suite , now i can connect my phone to my compter but when i trying to scan it there are just writing " scaning usb port " sorry for that im newbie for software.. can any bro show me image that how to solve this? thanks a lottttt |
09-21-2012, 10:36 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @hongmoblie If this is your first time working with Nokia Phones and USB connection, then you need to read more about how this phone can be unlocked... For starters,, 2700 with RAP3Gv3 CPU cannot be unlocked with USB cable alone. You need FBUS to Authorize the phone, then decrypt PM 120, then Bruteforce the hashes to get teh 15 digit unlock code. So you better read more about SL3 unlocking first so you will have a basic knowledge about which phones can be unlocked using USB connection only and which phones requires FBUS Cables. P.S. You did not need to install PC Suite,, actually PC Suite will make it harder to connect the phone... You only needed to install C:\AdvanceBox Turbo Flasher\Driver\Nokia_Connectivity_Cable_Driver_7.1 .78.0.msi |
