01-07-2013, 15:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: MX-KEY is the BEST NOKIA TOOL. Age: 39
Member: 747537 Status: Offline Thanks Meter: 39 | nokia lumia 610 dead |
01-08-2013, 06:35 | #4 (permalink) |
Member: 747537 Status: Offline Thanks Meter: 39 | Windows Phone Flashing Started AMSS File Found: RM835_12w47_prod_generic_amss.esco WPOS File Found: RM835_12470_prod_454_03_boot.esco USER AREA ERASE File Found: RM835_12w47_prod_generic_user_area_erase.esco WARNING: OSBL File is not Loaded WARNING: MODEM ADSP File is not Loaded ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== ================================================== ==== [/B] but when i connect phone its didect like qualcomm hs-usb qdloder 9008(cop416) this show in device mannager |
01-09-2013, 12:53 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Then your phone has boot-loader problem. Connect TP and Repair boot-loaders with ticked: M.B.R (Master Boot Record) SEC_BOOT OSBL DLOAD (NOKIA) After you can flash the phone with USB cable. BR |
02-20-2013, 10:29 | #6 (permalink) |
Junior Member Join Date: Feb 2013 Location: india
Member: 1887070 Status: Offline Thanks Meter: 0 | hi i hv problem eith nokia lumia 610....last time i drop my phone and break touch and lcd.....after changing lcd and touch my phone not start......i try to flash with ncs(nokia care suite) bt my phone not detect itry all things plz help me...........what can i do.... |
02-21-2013, 20:26 | #7 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
This is ATF Box Support Section. If you have the box, then please show us error logs from it. BR | |
01-23-2014, 06:52 | #8 (permalink) |
Freak Poster Join Date: Aug 2006 Location: tuticorin Age: 38
Member: 328758 Status: Offline Sonork: 1603668 Thanks Meter: 56 | ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! Try to Adjust VCCIO Voltage CMD1 Reply: 0x5E5E5E5E BOOT Images Written Successfully! Total Elapsed Time 00:00:19 |
01-23-2014, 10:30 | #9 (permalink) | |
BR | |
01-24-2014, 16:39 | #10 (permalink) |
Freak Poster Join Date: Aug 2002 Location: Poland Age: 44
Member: 15122 Status: Offline Thanks Meter: 18 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E BOOT Images Written Successfully! Total Elapsed Time 00:00:11 Lumia 610 NFC |
01-25-2014, 10:45 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, are you using lumia 610 NFC Test Point from C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX\610_NFC_TP.jpg ? |
02-19-2014, 09:26 | #12 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Everywhere
Member: 1413143 Status: Offline Thanks Meter: 15 | Hi, I have a problem. I have an Lumia 610, and when i connect battery only vibrate whitout touching anything. If i press power button nothing happen. I tried flash it, with 3 diferent firmware, but got same error each time: Code: Windows Phone Flashing Started AMSS File Found: RM835_12w16_prod_generic_amss.esco WPOS File Found: RM835_12160_prod_442_01_boot.esco USER AREA ERASE File Found: RM835_12w16_prod_generic_user_area_erase.esco WARNING: OSBL File is not Loaded WARNING: MODEM ADSP File is not Loaded ====================================================== Windows Phone Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ====================================================== Sending AMSS Certificate HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) ERROR: Data Rejected at SEQ 0x150 Status : AMSS WRITE FAILED Last edited by Udini; 02-19-2014 at 09:32. |
02-19-2014, 17:01 | #13 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Udini: Flash with fully charged battery and double check your downloaded files. If battery / files OK, try Repair Boot before you go for the hardware. BR |
