10-14-2014, 20:15 | #62 (permalink) | |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Quote:
10-17-2014, 13:12 | #63 (permalink) |
Freak Poster Join Date: Aug 2014 Location: bangladesh
Member: 2243030 Status: Offline Sonork: 1640811 Thanks Meter: 28 | Default language ID 0x0409 JTAG Interface Connected, S/N 0xA54139DF Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 22789377 ACTIVE Level 1 PUK: 46351243 ACTIVE Level 2 PIN: 84829846 Level 2 PUK: 37863096 Level 3 PIN: 67874406 Level 3 PUK: 72942425 Level 4 PIN: 44205602 Level 4 PUK: 08805684 Level 5 PIN: 13992041 Level 5 PUK: 38635144 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== Saving "..\Logs\Screenshots\2014-10-17_18-04-00.jpg"...OK |
10-29-2014, 12:11 | #64 (permalink) |
Crazy Poster Join Date: Feb 2014 Location: Ho Chi Minh VN Age: 35
Member: 2127434 Status: Offline Thanks Meter: 24 | 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 80425862 - LOCKED PUK LEVEL 1: 65863224 - LOCKED PIN LEVEL 2: 97025874 PUK LEVEL 2: 64115743 PIN LEVEL 3: 55385074 PUK LEVEL 3: 74932886 PIN LEVEL 4: 39273600 PUK LEVEL 4: 21896382 PIN LEVEL 5: 28567879 PUK LEVEL 5: 03409162 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done! |
11-17-2014, 10:50 | #66 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | connections wires and every thing is ok but getting error..... phone not conected. why????? Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x80000000 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! |
11-18-2014, 16:47 | #67 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 59297733 Level 1 PUK: 21975281 Level 2 PIN: 16654778 Level 2 PUK: 75742155 Level 3 PIN: 20530843 Level 3 PUK: 31154673 Level 4 PIN: 38709447 Level 4 PUK: 61122657 Level 5 PIN: 89885815 Level 5 PUK: 53087842 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== |
12-24-2014, 13:07 | #68 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1738521 Status: Offline Thanks Meter: 0 | ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 20472065 ACTIVE Level 1 PUK: 76662638 ACTIVE Level 2 PIN: 92749678 Level 2 PUK: 65573807 Level 3 PIN: 23982871 Level 3 PUK: 01992669 Level 4 PIN: 44568892 Level 4 PUK: 44719717 Level 5 PIN: 73710320 Level 5 PUK: 45643501 =================================== Reading Unlock Codes Done! ================================================== ========================== |
10-17-2015, 18:24 | #73 (permalink) |
Freak Poster Join Date: Jan 2013 Location: RUSSIA
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | I have bought ATF GOld fully activated along with a nice Dolphin clip and wanted to ask : Is there a short or long term to unlock via JTag Lumia 520 ? |
The Following User Says Thank You to soulgsm For This Useful Post: |
11-03-2015, 09:00 | #74 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Lumia 610 RM-849 Successfully unlocked Code: ATF JTAG v1.0.15.8544 (6/17/2015) Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0x85255A22 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/8/2014 10:52:00 PM ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 93999784 - LOCKED PUK LEVEL 1: 90827310 - LOCKED PIN LEVEL 2: 29130096 PUK LEVEL 2: 75142400 PIN LEVEL 3: 76202382 PUK LEVEL 3: 23761180 PIN LEVEL 4: 25126113 PUK LEVEL 4: 39157703 PIN LEVEL 5: 02655721 PUK LEVEL 5: 48340198 ========================= Reading Unlock Codes Done! ============================================================================ 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================================================ All Done! |
11-06-2015, 19:44 | #75 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Is TRUE or not that are Spamming ALL Atf section?, you will be remaing w/o answer and all you Spamming post deleted. Only one is enough, or you think that Spamming all Section reveive Speed answer?...you are out way totally. BR |
