02-08-2013, 10:17 | #92 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1283794 Status: Offline Thanks Meter: 3 | carefully and with some handling you can use a diy mini mill and cut only the piece where you have tp-s. I use a tool like this for years. http://fl1.shopmania.org/files/p/ro/...i~30649634.jpg |
02-08-2013, 12:35 | #93 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | hi boss help me i geet cables st gpg for lumia but ever time i see this masagein box window ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! |
02-08-2013, 12:35 | #94 (permalink) |
02-08-2013, 15:05 | #95 (permalink) |
Freak Poster Join Date: May 2011 Location: india Age: 33
Member: 1579398 Status: Offline Sonork: 1991 Thanks Meter: 22 | [QUOTE=7even2nd;8914820]Nokia Lumia 800 unlocked done via TP by ATF Nitro Phone is from UNITED KINGDOM CABLE USE: - modified RJ45 cable from old nokia fbus cable of twister box - mini USB 5310 cable or CA-101 usb cable PROCEDURE: -Disassembled phone first - Now soldered TP and connect modified RJ45 cable to ATF box - and make MINI USB as your power supply that connected to PC. - Test point - run ATF software - select model 800 : RM-801 - click TEST CONNECTION - put check LUMIA 800 RM-801 - then click SP UNLOCK -Finish Unlocking - after unlocking process assemble the phone - power on phone with any simcard - enter 00000000 as your PIN PHONE UNLOCKED DONE - now using GLOBE sim card good post share broooooooooooooo |
02-10-2013, 06:34 | #96 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: PH/Singapore/Malaysia
Member: 923652 Status: Offline Sonork: 1601428 Thanks Meter: 89 | Quote:
please help how to fix this error | |
02-16-2013, 19:11 | #98 (permalink) |
Freak Poster Join Date: Aug 2009 Location: bangladesh Age: 34
Member: 1104393 Status: Offline Sonork: 100.1603062 .::RONY::.. Thanks Meter: 130 | today i Nokia Lumia 800 unlocked done via TP by ATF box. |
The Following User Says Thank You to .::RONY::. For This Useful Post: |
02-24-2013, 20:42 | #100 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1784273 Status: Offline Sonork: 100.1618700 Thanks Meter: 43 | Lumia 800 Tp unlock process ATF 1.update your box 2.update your box Firmware 3.update important Files 4.reset box 5. Flash the phone with this firmware 1750.0805.8773.12220 firmware version for RM-801 OR RM-819 prodact code (059M117) use navi firmex To downlod 6.then solder tp 7. plug your phone ATF without battery without usb cable, when atf software tell you plug usb so plug usb then click test conection button 8.Finally press sp unlock button and wait 3-5 minute This is 100% solution Test by me |
03-05-2013, 21:48 | #101 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | as i understand its patch unlock for 800 so after reflashing phone will lock again my question is: does possibly for avoid reassembling phone just once unlock bootloader (using ATF) and after use ATF or NSS for easy unlock Lumia800 after flashing Thanx |
03-12-2013, 12:47 | #102 (permalink) |
Freak Poster Join Date: Jan 2010 Location: kolkatta
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | hi i have lumia 800 sir i cant unlock this phone please give me some advice here is log ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 0640007F Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:03 |
03-13-2013, 06:10 | #103 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ a f s a r Flash the phone & try to unlock . Information posted in FAQ thread about this Br - srinibas |
03-13-2013, 10:36 | #104 (permalink) |
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | still same problem after flashing here is log bro. Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 0640007F Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:02 |
