Nokia x repair boot via usb... plz i need help from team for repair boot nokia x (rm-980) via usb :confused: port com is "Qualcomm HS-USB Diagnostics 9006" and Qualcomm MMC Storage found but i have error. log : ERROR: Qualcomm MMC Storage USB is NOT FOUND Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Partitions Found: 0 |
If you are working with Windows XP or you do not have ADMIN rights, you can try this other EXE which I made: http://174.120.45.27/tmp/AdvanceBox_XP.rar Extract It to "C:\AdvanceBox Turbo Flasher\" or where you installed the ATF software... Then run it.. It should detect your 9006 now... |
