Nokia X Rm-980 IMEI Repair But No Service Nokia X (RM-980) Came to me with problem.. No showing imei and null baseband.. I repaired IMEI with ATF .... IMEI becom ok..but now set is in no service.... i checked PCB board...which is totally fresh.... customer tolde me that..this pro came in just working condition...mean...no any drpped or water damage issue... i again flashed too set...but same pro........ Pls gude me what i have to do now........thxxxxxxx |
Post phone info and flash log |
15:01:31 : ///////// /// /// /////// /////// ///////// 15:01:31 : /// /// /// /// // /// /// /// /// 15:01:31 : /// /// /// /////// /////// /// /// 15:01:31 : /// /// /// /// /// /// /// /// /// 15:01:31 : /// ///// /// /// /////// ////// 15:01:31 : 15:01:31 : ======================================= 15:01:31 : /// /// /// ///////// /////// ////// 15:01:31 : ///// /// /// /// /// // /// /// 15:01:31 : /// ///// /// /// /////// /// /// 15:01:31 : /// //// /// /// /// /// /// /// 15:01:31 : /// /// /// /// /// /// ////// 15:01:31 : ======================================= 15:01:31 : 15:01:39 : 15:01:39 : Enable USB debugging on your Phone 15:01:39 : Go to Settings -> About phone, 15:01:39 : and tap 5 times "Model", 15:01:39 : then tap 5 times "Software version", 15:01:39 : then go to Settings -> Developer Options 15:01:39 : and Enable USB debugging 15:01:39 : 15:01:39 : 15:01:39 : 15:06:03 : 15:06:04 : 15:06:04 : Scanning USB Ports... 15:06:04 : 15:06:04 : ================================================ 15:06:04 : Basic Phone Information 15:06:04 : ================================================ 15:06:04 : SW Version : 10.0.3 15:06:04 : Phone Model : Nokia_X 15:06:04 : Phone Type : RM-980 15:06:04 : SW Version : 10.0.3 15:06:04 : Serial Number : 365ac0ce 15:06:04 : 15:06:04 : ================================================ 15:06:04 : Extended Phone Information 15:06:04 : ================================================ 15:06:04 : Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140213.155540 test-keys 15:06:04 : Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140213.155540:user/test-keys 15:06:04 : Android OS Version : 4.1.2 15:06:04 : Product Platform : Nokia X software platform 1.0 15:06:05 : 15:06:05 : ================================================== ==== 15:06:05 : Selected VPL File: 15:06:05 : RM980_059T985_1.2.4.3_150.vpl 15:06:05 : ================================================== ==== 15:06:05 : Variant Details : RM-980 NDT IMEA IN 15:06:05 : Software Version : 1.2.4.3 15:06:05 : Product Type : RM-980 15:06:05 : Product Code : 059T985 15:06:05 : Variant Version : 150 15:06:05 : 15:06:20 : 15:06:20 : ================================================== ==== 15:06:20 : Nokia X/X+/XL/XL4G/X2 Factory Programming 15:06:20 : ================================================== ==== 15:06:20 : 15:06:20 : Power On the Phone and Connect it to the USB Port 15:06:20 : USB Debugging MUST BE Enabled in Developer Options 15:06:20 : 15:06:20 : ================================================== ==== 15:06:20 : 15:06:23 : SW Version : 10.0.3 15:06:23 : Phone Model : Nokia_X 15:06:23 : Phone Type : RM-980 15:06:23 : SW Version : 10.0.3 15:06:23 : Serial Number : 365ac0ce 15:06:23 : 15:06:23 : ================================================ 15:06:23 : Extended Phone Information 15:06:23 : ================================================ 15:06:23 : Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140213.155540 test-keys 15:06:23 : Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140213.155540:user/test-keys 15:06:23 : Android OS Version : 4.1.2 15:06:23 : Product Platform : Nokia X software platform 1.0 15:06:23 : 15:06:23 : Remounting System... 15:06:25 : Rebooting Device... 15:06:25 : Please Wait for Phone to Finish Booting... 15:06:27 : 15:06:27 : Entering Programming Mode... 15:06:27 : 15:06:27 : Make Sure to Install Correct Drivers from 15:06:27 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_ANDROID_FACTORY\ 15:06:27 : and 15:06:27 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\ 15:06:27 : 15:08:07 : Start Writing Phone Identity... 15:08:17 : 15:08:17 : Task Done! 16:11:02 : ================================================== ==== 16:11:02 : Selected VPL File: 16:11:02 : RM980_059T985_1.2.4.3_150.vpl 16:11:02 : ================================================== ==== 16:11:02 : Variant Details : RM-980 NDT IMEA IN 16:11:02 : Software Version : 1.2.4.3 16:11:02 : Product Type : RM-980 16:11:02 : Product Code : 059T985 16:11:02 : Variant Version : 150 16:11:02 : 16:11:07 : Nokia Android Phone Flashing Started 16:11:07 : 16:11:07 : 16:11:07 : ================================================== ==== 16:11:07 : Nokia Android Firmware Flasher 16:11:07 : ================================================== ==== 16:11:07 : 16:11:07 : If the Phone is ALIVE 16:11:07 : 1. Power On the Phone and Connect it to the USB Port 16:11:07 : 16:11:07 : If the Phone is DEAD 16:11:07 : 1. Press and Hold the VOLUME DOWN button 16:11:07 : 2. Connect it to the USB Port while still Pressing 16:11:07 : the VOLUME DOWN button 16:11:07 : 3. Continue to Press the VOLUME DOWN button for 15 16:11:07 : more seconds 16:11:07 : ================================================== ==== 16:11:07 : 16:11:28 : 16:11:28 : Processing QCSBL CONFIG 16:11:28 : Initiating File Download... 16:11:28 : Start Sending Blocks... 16:11:28 : All Blocks Sent: OK 16:11:28 : Writing to eMMC... 16:11:28 : All Blocks Written: OK 16:11:28 : Processing QCSBL 16:11:28 : Initiating File Download... 16:11:28 : Start Sending Blocks... 16:11:28 : All Blocks Sent: OK 16:11:28 : Writing to eMMC... 16:11:28 : All Blocks Written: OK 16:11:28 : Processing MODEM 16:11:28 : Initiating File Download... 16:11:28 : Start Sending Blocks... 16:11:31 : All Blocks Sent: OK 16:11:31 : Writing to eMMC... 16:11:36 : All Blocks Written: OK 16:11:36 : Processing OEMSBL HEADER 16:11:36 : Initiating File Download... 16:11:36 : Start Sending Blocks... 16:11:36 : All Blocks Sent: OK 16:11:36 : Writing to eMMC... 16:11:37 : All Blocks Written: OK 16:11:37 : Processing OEMSBL 16:11:37 : Initiating File Download... 16:11:37 : Start Sending Blocks... 16:11:37 : All Blocks Sent: OK 16:11:37 : Writing to eMMC... 16:11:37 : All Blocks Written: OK 16:11:37 : Processing APPSBOOT HEADER 16:11:37 : Initiating File Download... 16:11:37 : Start Sending Blocks... 16:11:37 : All Blocks Sent: OK 16:11:37 : Writing to eMMC... 16:11:37 : All Blocks Written: OK 16:11:37 : Processing APPSBOOT 16:11:37 : Initiating File Download... 16:11:37 : Start Sending Blocks... 16:11:37 : All Blocks Sent: OK 16:11:37 : Writing to eMMC... 16:11:37 : All Blocks Written: OK 16:11:37 : Processing BOOT 16:11:37 : Initiating File Download... 16:11:37 : Start Sending Blocks... 16:11:38 : All Blocks Sent: OK 16:11:38 : Writing to eMMC... 16:11:39 : All Blocks Written: OK 16:11:39 : Processing RECOVERY 16:11:39 : Initiating File Download... 16:11:39 : Start Sending Blocks... 16:11:40 : All Blocks Sent: OK 16:11:40 : Writing to eMMC... 16:11:42 : All Blocks Written: OK 16:11:42 : Processing PERSIST 16:11:42 : Initiating File Download... 16:11:42 : Start Sending Blocks... 16:11:42 : All Blocks Sent: OK 16:11:42 : Writing to eMMC... 16:11:44 : All Blocks Written: OK 16:11:44 : Processing SYSTEM 16:11:44 : Initiating File Download... 16:11:44 : Start Sending Blocks... 16:12:33 : All Blocks Sent: OK 16:12:33 : Writing to eMMC... 16:14:18 : All Blocks Written: OK 16:14:18 : Processing VARIANT 16:14:18 : Initiating File Download... 16:14:18 : Start Sending Blocks... 16:14:19 : All Blocks Sent: OK 16:14:19 : Writing to eMMC... 16:14:20 : All Blocks Written: OK 16:14:20 : Processing CACHE 16:14:20 : Initiating File Download... 16:14:20 : Start Sending Blocks... 16:14:21 : All Blocks Sent: OK 16:14:21 : Writing to eMMC... 16:14:23 : All Blocks Written: OK 16:14:23 : Processing USERDATA 16:14:23 : Initiating File Download... 16:14:23 : Start Sending Blocks... 16:14:27 : All Blocks Sent: OK 16:14:27 : Writing to eMMC... 16:14:34 : All Blocks Written: OK 16:14:34 : Processing UDISK 16:14:35 : Initiating File Download... 16:14:35 : Start Sending Blocks... 16:14:40 : All Blocks Sent: OK 16:14:40 : Writing to eMMC... 16:14:52 : All Blocks Written: OK 16:14:52 : Processing PRELOAD 16:14:52 : Initiating File Download... 16:14:52 : Start Sending Blocks... 16:15:39 : All Blocks Sent: OK 16:15:39 : Writing to eMMC... 16:17:11 : All Blocks Written: OK 16:17:11 : 16:17:11 : Flashing Done! 16:17:11 : Total Flashing Time (Erase + Flashing) : 00:05:43 16:17:11 : 16:17:11 : Rebooting to Normal Mode... 16:23:02 : Nothing to Restore... 16:23:02 : Please Select Partition Files 16:23:02 : 16:28:39 : Shutting Down ADB Server... 16:28:39 : 16:28:39 : If your Phone is still not detected by 16:28:39 : ATF Software, manually End Process adb.exe 16:28:39 : in Windows Task Manager... 16:28:39 : 16:28:39 : 16:28:39 : ================================================== ==== 16:28:39 : Nokia X/XL/X2 IMEI and Simlock Backup 16:28:39 : ================================================== ==== 16:28:39 : 16:28:39 : Power On the Phone and Connect it to the USB Port 16:28:39 : USB Debugging MUST BE Enabled in Developer Options 16:28:39 : 16:28:39 : ================================================== ==== 16:28:39 : 16:29:03 : 16:29:03 : Starting Connection... 16:29:09 : 16:29:09 : Starting Connection... 16:29:32 : 16:29:32 : ================================================ 16:29:32 : Extended Phone Information 16:29:32 : ================================================ 16:29:32 : 16:29:32 : Preparing Local Directory... 16:29:33 : ERROR: ROOT Access Failed! 16:29:33 : 16:29:39 : Shutting Down ADB Server... 16:29:39 : 16:29:39 : If your Phone is still not detected by 16:29:39 : ATF Software, manually End Process adb.exe 16:29:39 : in Windows Task Manager... 16:29:39 : 16:29:39 : 16:29:39 : ================================================== ==== 16:29:39 : Nokia X/XL/X2 IMEI and Simlock Backup 16:29:39 : ================================================== ==== 16:29:39 : 16:29:39 : Power On the Phone and Connect it to the USB Port 16:29:39 : USB Debugging MUST BE Enabled in Developer Options 16:29:39 : 16:29:39 : ================================================== ==== 16:29:39 : 16:29:40 : 16:29:40 : Starting Connection... 16:29:40 : SW Version : 1.2.4.3 16:29:40 : Phone Model : Nokia_X 16:29:40 : Phone Type : RM-980 16:29:40 : SW Version : 1.2.4.3 16:29:40 : IMEI #2 Plain : 353070063907188 16:29:40 : IMEI #1 Plain : 353070061907321 16:29:40 : Serial Number : 365ac0ce 16:29:40 : 16:29:40 : ================================================ 16:29:40 : Extended Phone Information 16:29:40 : ================================================ 16:29:40 : Baseband Version : 8X25-SSRSKOLYM-3072 16:29:40 : Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140806.091438 test-keys 16:29:40 : Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140806.091438:user/test-keys 16:29:40 : Android OS Version : 4.1.2 16:29:40 : Product Platform : Nokia X software platform 1.2 16:29:40 : 16:29:40 : Preparing Local Directory... 16:29:40 : Remounting System... 16:29:40 : Reading MODEM_FSG Partition... 16:29:40 : Reading MODEM_ST1 Partition... 16:29:40 : Reading MODEM_ST2 Partition... 16:29:41 : Reading NVBK Partition... 16:29:41 : Moving Files... 16:29:41 : Moving MODEM_FSG File... 16:29:42 : Moving MODEM_ST1 File... 16:29:44 : Moving MODEM_ST2 File... 16:29:45 : Moving NVBK File... 16:29:47 : All Files Moved! 16:29:47 : Clean Up... 16:29:47 : 16:29:47 : Task Done! 16:29:47 : Files Saved to: 16:29:47 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\353070061907321\January_07_20 16_Thursday_16_29_41\ 16:29:47 : Total Backup Time : 00:00:07 16:35:37 : 16:35:37 : ================================================== ==== 16:35:37 : Nokia X/XL/X2 IMEI and Simlock Restore 16:35:37 : ================================================== ==== 16:35:37 : 16:35:37 : Power On the Phone and Connect it to the USB Port 16:35:37 : USB Debugging MUST BE Enabled in Developer Options 16:35:37 : 16:35:37 : ================================================== ==== 16:35:37 : 16:35:37 : 16:35:37 : Starting Connection... 16:35:37 : SW Version : 1.2.4.3 16:35:37 : Phone Model : Nokia_X 16:35:37 : Phone Type : RM-980 16:35:37 : SW Version : 1.2.4.3 16:35:37 : IMEI #2 Plain : 353070063907188 16:35:37 : IMEI #1 Plain : 353070061907321 16:35:37 : Serial Number : 365ac0ce 16:35:37 : 16:35:37 : ================================================ 16:35:37 : Extended Phone Information 16:35:37 : ================================================ 16:35:37 : Baseband Version : 8X25-SSRSKOLYM-3072 16:35:37 : Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140806.091438 test-keys 16:35:37 : Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140806.091438:user/test-keys 16:35:37 : Android OS Version : 4.1.2 16:35:37 : Product Platform : Nokia X software platform 1.2 16:35:37 : 16:35:37 : Preparing Local Directory... 16:35:37 : Copying Restore Files... 16:36:10 : Initializing ROOT Access... 16:36:10 : Remounting System... 16:36:10 : Writing MODEM_FSG Partition... 16:36:10 : Writing MODEM_ST1 Partition... 16:36:10 : Writing MODEM_ST2 Partition... 16:36:11 : Writing NVBK Partition... 16:36:11 : Clean Up... 16:36:11 : Rebooting Device... 16:36:11 : 16:36:11 : Task Done! 16:36:11 : 16:36:11 : Total Restore Time : 00:00:33 |
