Nokia x1-01 rm-713 Problem Was'' Dial / Received / Miss Call Not Showing Nokia x1-01 rm-713 Problem Was'' Dial / Received / Miss Call Not Showing. Than I Doing Flash But No Luck Any Body Know About This Problem For Infineon CPU Proper Solution. Here Flash Log:- Code:
Here Self test Log:- Code:
I also have same problem................. also unable to remove its security code,cant flash it. |
Nokia x1-01 rm-713 Problem Was'' Dial / Received / Miss Call Not Showing This water demage clen off all ic and slow hetup......... |
Palash It is a hardware fault , Not solve by flashing . Replace the diode near crystal Br - srinibas |
full detail post here.... Thanks in Advance. |
solved by flash after wash ............ |
