10-01-2014, 16:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | Lumia 920 flashing error Lumia 920 flashing error see log, i have using flash file RM821_3051.50009.1424.0009_RETAIL_im_india_443_09_ 441109_prd_signed Code: Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8/8.1 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ====================================================== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... IMEI: 354149059733417 Version: 1.1.1.3 Product Code: 059R2B9 Module Code: 0205137 Basic Tranceiver Code: 059N5Q1 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00000000 Block ID 0x05 : Nokia.MSM8960.P4301.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C49BC0DB952A6BB4 Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
10-02-2014, 10:55 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mobilegsm30 Make sure Phone battery is 100% Charged Flash Phone with matching product code flash file. If you REALLY want to use this flash file, then you can first Flash it via FFU Flashing in JTAG. Then the phone will for sure accept this flash file after. You can even make RM-821 phone accept RM-820 flash file, but you need to flash it via JTAG first. You cannot crossflash via USB alone. B.R. |
10-03-2014, 15:25 | #3 (permalink) | |
Member: 129486 Status: Offline Thanks Meter: 66 | Quote:
Code: Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0xDF4362E0 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 25/06/2014 11:29:00 PM ========================================================== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Boot Package: 3051.40000.1351.2005 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/09/2014 3:37:00 PM ========================================================== Phone Type : Lumia 920, 920T CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 15 second(s)...Timeout During Operation! Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/09/2014 3:37:00 PM ========================================================== Phone Type : Lumia 920, 920T CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x0EBC011B IR4 Device #2 ID 0x84703B81 IR10 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Loading AFP (Please Wait)...OK AFP revision 4, compiled 25/06/2014 11:29:00 PM ========================================================== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Boot Package: 3051.40000.1351.2005 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x0EBC011B IR4 Device #2 ID 0x84703B81 IR10 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x0EBC011B IR4 Device #2 ID 0x84703B81 IR10 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) | |
10-03-2014, 15:42 | #4 (permalink) |
Member: 129486 Status: Offline Thanks Meter: 66 | And some time give error Code: Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0xDF4362E0 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x0EBC011B IR4 Device #2 ID 0x84703B81 IR10 Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/09/2014 3:37:00 PM ========================================================== Phone Type : Lumia 920, 920T CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x0EBC011B IR4 Device #2 ID 0x84703B81 IR10 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/09/2014 3:37:00 PM ========================================================== Phone Type : Lumia 920, 920T CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Shift IR Error(s) |
10-03-2014, 16:04 | #5 (permalink) | |
Code: Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0xDF4362E0 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x706B40E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/09/2014 3:37:00 PM ========================================================== Phone Type : Lumia 920, 920T CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...90014A48424734650401003EA2F02030 Flash Description: Hynix HBG4e, 29.12 GiB, SN 003EA2F0, Feb 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...90014A48424734650401003EA2F02030 Flash Description: Hynix HBG4e, 29.12 GiB, SN 003EA2F0, Feb 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...OK (6066 Op/Sec) FFU File Loaded: RM821_3051.50009.1424.0009_RETAIL_im_india_443_09_441109_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xB8CFE305 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...Flash Write Error at 0x00000200, Loader Error, Code 0x71 | |
11-19-2014, 07:48 | #6 (permalink) |
Junior Member Join Date: Jun 2014 Location: India
Member: 2211015 Status: Offline Sonork: 100.1604150 Thanks Meter: 1 | After repair with jtag same product file phone give same error on flashing i have 4 phone in same problum plz give me any solution (Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed!) |
11-19-2014, 20:11 | #7 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Quote:
