11-03-2010, 07:48 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1351542 Status: Offline Thanks Meter: 31 | problem in atf box ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ****************************************** INIT : FAILED , CHECK YOUR BOX FIRMWARE ****************************************** sir i m new user i pruchase a atf box which is preactived to my friends name ,but when i conneceted to my pc it shows error,i did every thing which is given on this error,i also tried to restore box but it shows in last box error... now pls help me....... |
10-13-2014, 10:42 | #13 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @msnoman If you are using 11.70 from FULL INSTALLER, then please read this: http://forum.gsmhosting.com/vbb/f609...ponse-1864764/ |
11-19-2014, 14:54 | #14 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1985217 Status: Offline Thanks Meter: 0 | i have a huge problem with my atf sir, i have the same problem,first my atf box says " multiple atf box detected" i read some other post and said that i need to use Mprog 3.5, i have done all the instruction they've posted and now my atf box serial no. is 00000000, they said that i need to restore my box. i tried to, but i got this sort of a warning that said "$ , pls,pls,pls. what do i have to do? |
11-19-2014, 18:14 | #15 (permalink) |
Member: 1985217 Status: Offline Thanks Meter: 0 | finally, my box is working now. i downloaded and installed v.11.70. then i go to product support/update files/ update important files. after it is done. then go to product support/boxtools/restore box, and wallah....... its working. what can i say? thanks to the product manager. |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
