11-20-2010, 14:22 | #94 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Manchester, UK
Member: 180873 Status: Offline Thanks Meter: 80 | ATF box repair My box worked fine for the first day then caused problems, so I followed the modify PCB method and it seems to work fine for now, STEP 1 ( REMOVE COMPONENTS ) : STEP 2 ( MAKE JUMPER ) : STEP 3 (WRITE SPECIAL FIRMWARE) STEP 4 (Restore/update box via main software) Maybe this will be a bit more clearer for some people |
The Following 3 Users Say Thank You to javakiller For This Useful Post: |
11-28-2010, 15:22 | #95 (permalink) |
Junior Member Join Date: May 2007 Location: perambalur
Member: 501123 Status: Offline Sonork: [email protected] Thanks Meter: 8 | my atf box LT1930 is broken,only disply blue led ,please equalent value of new regulator ic value ple reply |
12-09-2010, 10:21 | #96 (permalink) |
Freak Poster Join Date: May 2008
Member: 777756 Status: Offline Thanks Meter: 44 | i was having problem in atf of green light i did all things as above handset is now flashing but as i treid to read information or any other function it is not oprating pl help. |
12-19-2010, 12:52 | #101 (permalink) |
Freak Poster Join Date: Dec 2008 Age: 56
Member: 923032 Status: Offline Sonork: 321321 Thanks Meter: 17 | AdvanceBox Turbo Flasher Found Driver Version : 00020601 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 8.15.10 Software Version : v6.10 AdvanceBox SN : DF0DC573D4C0C9FFDBAF8A78 BOX Status : ACTIVATED INIT : OK VBATT OFF... VBATT ON Setting VBATT Done!... ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= ERROR : PHONE READ INFO FAILED ERROR : PHONE READ INFO FAILED ERROR : PHONE READ INFO FAILED ERROR : PHONE READ INFO FAILED i cannot flash the phone i cannot do anything with this box. please give me the solution please please please |
12-23-2010, 16:31 | #102 (permalink) |
Freak Poster Join Date: Mar 2009 Location: India
Member: 1001635 Status: Offline Thanks Meter: 63 | sir My atf box can not boot any set from yesterday though The green light is lightning ok. I reinstall the drivers as well as the box v6.10 softwares.I have also updated the fimware bot the problem has not solved yet. Please help...................... |
12-23-2010, 23:21 | #103 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Gsm Works
Member: 162332 Status: Offline Sonork: 100.1578458 Thanks Meter: 36 | for this also new pcb what is the solution.....................i run the software all and driver install properly the box cannot detect...atf box not found all i doing they same problem...box not detect...new box days....pls..make solution this |
12-25-2010, 12:38 | #105 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | after i make all steeps i can flash but i can not read info and i can not make factory reset ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... |
